Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Unable to render |
| Print at Sep 20, 2026, 6:09:34 PM | View all posts in this thread on one page |
| Posted by crackwood01 at Oct 17, 2022, 4:12:56 PM |
Unable to renderHi, i can't render my project. I don't know if it is a particuler object thats create a bug. I've always been able to use yafaray or another motor. Nohing happens at all, just a grey screen. http://www.crflix.ca/docs/Projection.sh3d Merci!! |
| Posted by Puybaret at Oct 17, 2022, 6:16:43 PM |
Re: Unable to render I just tried your file and had no problem. Did you succeed to render that particular project? Did you relaunch Sweet Home 3D? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by crackwood01 at Oct 25, 2022, 11:38:04 PM |
Re: Unable to render i can render other projects but not this one |
| Posted by Daniels118 at Oct 26, 2022, 5:29:36 PM |
Re: Unable to render You have a 3D dimension line hidden behind the shower. Please note that the versions of 3D dimension lines plugin prior to 3.1 break the rendering (if a 3D dimension line is in the scene). Please check if you have the latest version of the plugin. I recommend to use the Plugin manager with "check for updates" option enabled to keep all plugins updated. |
Current timezone is GMT Sep 20, 2026, 6:09:34 PM |
