Re: Windows 11 - not possible to open/save/save-as
Maybe check that security settings don't forbid you to save some files from Sweet Home 3D application, following these instructions.
Deutschland
Dear Puybaret,
thanks for the reply! I checked the setting, but my "Windows Security" is disabled though I use Norton 360. I checked the settings of this Application aswell, but even disabling the full package and looking at the detailed history does neither give any useful information nor make any difference...
Can you download a demo of the Gallery and try to open it by double-clicking on the downloaded file? If it works, try to modify it and save it.
Deutschland
I downloaded the file, opened it by double-clickin, changed something and hit "save". That did actually work! "open" or "save-as" still does not work, but the changes I did were saved.
At least, you can start from an existing file and modify it. Nevertheless, it would be nice to understand why the file dialog box doesn't appear. Could you run Sweet Home 3D from the command line as explained here to get logs when you select Open or Save as menu item?
I wanted to share that the same issue is occurring for me as well. I installed 7.0.2 today and am not able to save my work. I tried using a gallery file to alter and am still unable to save.
I tried to launch from command line as advised above, but nothing is writing to my designated log file when I perform actions in the client.
@Arbor What error does the program report when you try to save (not save as) an existing file?
Deutschland
I tried to use the command "SweetHome3D.exe -log MyLogFile.log", first time the file was created writing "system could not find the file" (in german ;-) ), another try and the system did not even create this file...
No error messages presents for me, it just does not perform the save. The asterisk still appears by the filename in the upper corner. When attempting to close the program, it states the file has not been saved and prompts to save. It still does not save when following the prompt.
Deutschland
Correct, when I do not open an existing document, the changed will be saved (manually or by clicking "save" on closing), it is not possible to open or save-as, the window to choose a file/filename does not appear.
