Importing OBJ file in Sweethome3D
Hello there.
I just bought a 3D model of a stove at CGTrader. The download section proposes .MAX, .OBJ, and an additional maps.rar file.
When importing the OBJ file in Sweethome3D, the wood burning stove is all gray. There are no texture. I guess the maps.rar contains textures and details ? How can I have the full object imported in Sweethome3D ?
Italy
Re: Importing OBJ file in Sweethome3D
The obj file alone isn't enough, it must come along with a mtl file (materials) and zero or more image files (textures). The archive should contain all of them, so you have to extract everithing without altering the directory structure. When importing just select the obj file, the program will find other files by itself.
Be aware that downloaded objects from sites like Archive3D and CGTrader are often a little 'broken' with parts not correctly lined up or unmapped textures. This is especially true for the free objects. Try either a 3DS or FBX version since those often offer better results than an OBJ+NTL file.
On CGTrader the FBX versions are generally the best (in my experience) but you have to use a program like Blender to import them and export them to a 3DS file which can be imported by SH3D. It's an option if the original 3DS or OBJ versions fail. You have a better chance of correctly mapped textures with a FBX or 3DS file. Blender is also useful to realign a wrong part of an object. A tip while importing objects from third party sites: many times the size seems wrong in SH3D because the scale is different. Check the number and in most cases moving the decimal point one or two places to the left will give you the correct dimensions.
Even if textures are not mapped you can (re-)create an otherwise good object by manually mapping the textures using the Color and Texture Modify button in SH3D. Of course this requires that the different parts are correctly listed in the object file. If you encounter just a single item to map you are out of luck because there are no parts to map.
Most of the Archive3D files can be imported without a problem but the rar files sometimes show 0 files (some are very old). Specifically on Linux I found that some rar files from Archive3D can only be extracted with p7zip (a Linux port of 7zip). SH3D expects a zip file so the rar file must be extracted anyway. It is advisable to copy textures that are in a subdirectory to the directory where the OBJ/MTL or 3DS file is. This often avoids the need to manually map the textures in SH3D.
Thanks it works! But last versions of blender won't export in 3ds, so you either need to get a legacy version (2.9 or less), or install a custom addon.
Canada
Wow! I'm really struggling trying to use this program! I figured out how to import models, like a bed with drawers today, but all I get is a one color one that I can't do anything with, not the original model. No idea why.
First check if you also downloaded the .mtl file that comes with the .obj file. Without it you will have no materials. Usually the .mtl file has the same name as the obj file and is in the same directory as the .obj file. On some sites you need to download is separately from the .obj file. Also make sure that you download all the texture images that belong to the model. This too is sometimes a separate download. In short: you need an .obj file, an .mtl file, and texture images (if any).
Many sites with 3D models often give the option to download the model in different file formats. The most used that you can import in Sweet Home 3D are OBJ, 3DS, and DAE. If you get a model with a single material as you described then you can check if one of the other types is available with the same model. Maybe then you get the correct materials. A STL file is for 3D printing and is always with a single material (i.e. none).
If none of the options gives you a model with correct materials you will have to use a program like Blender to create and set materials to different parts of the model. Note that none of the models you import from an external site will have opening parts, unless the model is specifically created for Sweet Home 3D (like my site dodecagon.nl).
A little trick that makes importing easier: you can drag an .obj, .3ds, or .dae file from the file manager in the 2D design pane of Sweet Home 3D. You can even select and drag multiple files at the same time. The advantage is that it will import at the position where you drop the file. (The same with textures: you can drag an image file in the image preview window where you select/set a texture.)
