Previous Thread This topic has been viewed 1729 times and has 2 replies Next Thread
mikedj
Imported Furniture Low Resolution in Plan View
When I import furniture created in Sketchup, it looks fine in SH3D 3D view, but is very pixelated in SH3D Plan View.
My procedure is:
- Create a solid model in Sketchup
- Export the 3D model as either .dae or .kmz
- Import furniture in SH3D
- Drag the new furniture to the plan
Sketchup model:
SH3D 3D view:
SH3D Plan view:
Note that I added the texture in SH3D, which offers a little more visual clarity, but the issue exists even without the texture.
I've also noticed a similar issue when using the "Generate 3D from rooms" plugin.
Is there a setting or settings that affect import resolutions? Or settings for the plan view resolution?
Thank you,
[Mar 18, 2022, 6:12:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Imported Furniture Low Resolution in Plan View
See the Icon size setting in preferences pane.
But keep in mind that it will apply to all icons and a higher value may require a lot of RAM to handle all icons.
[Mar 18, 2022, 6:56:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mikedj
Perfect!
Thank you!
[Mar 18, 2022, 7:31:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
