Total posts in this thread: 9
Previous Thread This topic has been viewed 5307 times and has 8 replies Next Thread
wismeijer
The Netherlands
Furniture not importing on MacBook Air M1
Hi guys, having trouble importing new furniture on SH3D.
When I download a (Collada) ZIP file from 3D Warehouse, I can load it but when the orientation screen appears SH3D 'hangs' and I have to force quit the app.
Anybody else having this problem?
Version used:
Versie 6.6.1 Mac App Store
OpenJDK versie 15.0.2 - 64bit - ARM - 0,1 / 4 GB geboden door Azul Systems, Inc. Java 3D versie 1.6.1 - JOGL 2.4.0-rc-20210111
[Feb 13, 2022, 12:33:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Furniture not importing on MacBook Air M1
Try to run the program with Rosetta at least while you import a 3D model. What macOS version do you use?
[Feb 13, 2022, 6:55:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snortrip
I had a similar problem. So far, unfortunately, I could not find a solution.
My favorite collection of 3D furniture models is here.
[Feb 14, 2022, 12:53:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snortrip, are you sure you use Sweet Home 3D 6.6.1 like wismeijer?
[Feb 14, 2022, 3:41:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
UbuntuBirdy
I have the same problem with the current version of SH3D for Linux on Ubuntu 21.10.
Pascal
[Mar 5, 2022, 9:53:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pharmonie
Germany
Same here. MacBook Pro 14" 2021 with M1 Pro. It's freezing in the orientation view after selecting in obj file to import. using Sweet Home 3D Version 6.6a.
Did you guys find any workaround yet?
I can confirm, that importing entire libraries is working.
[Mar 7, 2022, 3:01:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Pharmonie, your case is a little different because you use the free version in which case you should use the special version available at
https://www.sweethome3d.com/downloads/SweetHome3D-6.6-macosx-jogl-2.3.2.dmg
As this version can't be notarized, you'll have to launch it the first time by clicking on Sweet Home 3D icon while maintaining control key pressed and choosing Open item.
[Mar 7, 2022, 4:17:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
UbuntuBirdy
As a workaround I import the models with the FLE, save it in a library and then import that library with SH3D.
Works for me with Ubuntu 21.10 and SH3D 6.6. Hope that's a (temporary) solution for the M1 too.
Pascal
[Mar 7, 2022, 11:05:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
snortrip
Puybaret, thank you! This solution worked fine in my case.
[Edit 1 times, last edit by Puybaret at Mar 31, 2022, 11:36:04 AM]
[Mar 30, 2022, 3:33:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
