Re: Ceiling is not close to the walls
You must have created more than one level and didn't set a height for the level matching the height of your walls. The height of a level is used to know the elevation of ceilings (except for the last level).
Don't delete anything, just select the first level and modify its height in the level modification dialog box.
Add a dummy level, because slanted ceilings are computed only at the last level.
By "dummy", I meant a level that you won't actually use, but that will change the algorithm which computes ceiling at the before last level.
