Romania
Re: Generate roof plugin
News (no breaking)! In the last several months I've made some kind of team with Daniels118. That's mean I make a wish and he make it real. Then I make it public like it is my work. In fact that's all my effort. Anyway, it was a heavy time consuming and a lot of try and fail, than start from the beginning.
What's new (not to mach): 1. Individual face selection with mouse (thanks to Emmanuel & Daniele), 2. Individual face angle set (thanks to Daniele), 3. Add a Help button with some useful information (I've stole some codes from Daniele). -Add Chinese translation (thanks to YGYL but incomplete at that moment, need updated). As You could see I have nothing to do with this version.
Some screenshots and explanations (for new comings): - Start from a selected room as roof projection (generated by Auto Dimensioning plugin or manually drawn)
- Tools->Generate roof
- You will see something like this
- Select a face with mouse
- Rotate roof and select other face.
- Press Ctrl+click on other face
- Click elsewhere to deselect all, select a face, then Ctrl+Click to select desired faces.
- With this selected faces modify faces angle with the slider.
- Make the same with other faces
- Click Ok to export roof on home
- Open in Modify furniture -> Modify materials Select all faces and set the desire texture
- Select some specific faces and mark as invisible. Ok.
- That could be the result
Also on Source Forge
Hello Team Dorin,
Thank you very much for this new version. It works, more or less.
I followed the steps in Dorin's message, and this is what happens: - the plugin generates a correct roof - the new interface appears with the angle slider - however, the list with roof sections is not visible, and - I cannot select individual roof parts in the 3D preview - after clicking OK I try to apply textures - when I select Modify Roof, I can apply textures to each individual roof section
Maybe you published version 2.9 instead of v3.0 ??
Italy
Hi Hans, the angle slider was already there in the previous version (2.5), the version 3 adds the faces list and the help button. If you click the help button you will see the current version. Also note that this version requires SH3D 7.0 or later.
Please be sure you have installed the latest version and don't forget to restart SH3D to let the changes to take effect. If you have done the steps above and still experience problems, please post a screenshot of the GUI.
Did you look at the previous messages? Just try to reproduce some similar rooms.
Australia
Hi Dorin, I have a rectangular Roof and the Roof loads with the 2 Sides and the 2 Ends at 45°. I would like to change the angle of the 2 Ends to be a different angle. How can I achieve that please? Regards Graham
Australia
Hi Dorin, Please ignore my earlier message. I have now read your earlier message with illustrations and I believe the answer is in there. Regards Graham
Australia
Hi Dorin, Despite all attempts I am unable to Use your Plugin to create my Roof. I hope you will help me here .... I'm wanting a 5m wide roof at the Northern end, running East/West and then 3 Ridges running North/South with an East/West wing over the Port Couchere in the South. Can you help me with GenRoof please?
