I've tried removing all my other plugins to see if it is a conflict, but it still didn't work. I've tried both MediaFire and SourceForge versions. Still didn't work.
Only thing I can think of that is left is my SH3D is version: 7.0j (a patched version from Emmanual as I recall) on Windows 10.
Re: Generate roof plugin
Nope. I'm now on the newest 7.0.2. No plugins apart from the roof generator. I have no Tools menu at all, and the libraries in the about dialog is not showing anything.
Sorry Dorin, but it doesn't work on my side too, with the log reporting this:
Invalid plug-in jar:file:/Users/manu/Library/Application%20Support/eTeks/Sweet%20Home%203D/plugins/GenerateRoof.sh3p!/generateroof%2FApplicationPlugin.properties: Can't find resource for bundle java.util.PropertyResourceBundle, key name
Probably, an issue in a properties file (if you don't use English, it may not happen).
I'll post a theory. In the previous version all the properties were in a default unlocalised poperty file. In this version many of the values were moved into an en_US property file. I'm a Brit, so my localisation is en_GB. Usually applications fall back to en_US, but it seems you are not doing this, so for anyone not using en_US, fr, it, or zh_CN, the plugin will not work. Another option would be to rename the property file to just be en, not en_US.
Try to fix a bug which prevent loading plugin on some OS with global language settings other than en_US. Hope this time will work for everyone.
Also on Source Forge
Thanks, it works now. The ApplicationPlugin.properties file is the default properties file for all languages and should contain all the properties you may use in the plug-in. If you want to specify some different values for some properties like translation or special values for the English in the USA for example, you can create additional properties files with other suffixes like _fr or en_US, but you should not add new properties in these files.
