Generate roof plugin
This topic has been viewed 3153859 times and has 338 replies
Thread status: Active
Questions about extending features and developing plug-ins [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
Country: UK
Re: Generate roof plugin
Post by Mike53 »
Nice improvements to a very useful plug-in.
User avatar
Country: Netherlands
Post by hansmex »
I did a few quick tests on demo houses from the gallery, and (in combination with the Autodimensioning plugin) it works beautifully.
I'm missing just one thing...
There are two options for the Border - vertical and perpendicular to thr roof slope. Can we have a third option - horizontal?
Thank you very much D+D !!
User avatar
Xlance
Post by Xlance »
Outstanding ! Thank You
Windows 64bit | Intel i7 | SH3D 8.0 + Plugins
User avatar
dorin
Country: Vatra Dornei, Suceava, Romania
Post by dorin »
Version 5.1
Downloadable from here or here . Also available through Plugin Manager.
and
Roof windows library version 0.3 downloadable from here or here .
What it can do:
-Generate a roof object based on a closed polygon (a SH3D room)
-It can make holes for roof windows, provided they are from the specific library
-It can generate roofs for buildings with holes, such as inner courtyards.
-You could make some overlapping roofs.
What it cannot do:
-It cannot model an object. It regenerates a new one every time you change a parameter.
How it works:
-Select a previously created room or roof and execute Tools ->Generate roof...
Note: If nothing specific is selected, Generate Roof... is grayed out.
It should look like this:
Some explanations:
1. Roof preview. Use the mouse to:
- rotate the preview
- select current roof face(s):
- Ctrl + mouse click -> select different faces
-Shift + mouse click -> select a continuous series of faces
2. View panel. Choose the viewpoint and how you see (parallel/perspective)
3. Choose what you want to see in the preview.
4. The roof total visible area.
5. The edges control panel
6. Modify coordinates panel:
-Choose Edge or Start point or End point to be modified.
-The X, Y, and Z coordinates are marked with the same color as the axes.
-Step: set the step value for X, Y, Z spinners.
- You can modify the roof geometry, such as roof overhangs, or create overlapping roofs.
7. Add/remove edge. It is active if Edge button is selected.
- With „+” will split the edge in two, generating corresponding edges.
- With „-” will delete the selected edge
8. Border panel where you can choose between vertical and orthogonal border.
-Keep in mind that borders surround the entire roof face.
9. The roof thickness.
10. The roof elevation. Will set also the level elevation.
11. Before saving the roof you could choose to reverse faces for use as a more customizable ceiling.
12. Undo, Redo and Reset button.
- Reset will load the initial roof.
13. The author field. It could be modified.
User avatar
Post by hansmex »
k005
Country: TURKEY
Post by k005 »
Looks beautiful. I installed the addition. However, he gave an error message. But he didn't write what the mistake was.
User avatar
dorin
Post by dorin »
You both have right! I'm so stupid to forget to verify the most simple situation.
I think I've fixed and I've updated the links.
Please download again and let me know if I've made a bigger mistake.
Sorry for the inconvenient. [:((]
k005
Country: TURKEY
Post by k005 »
It gives the same mistake again.
User avatar
dorin
Post by dorin »
Please verify inside of your plugin folder to not have multiple instances of it.
-Delete all GenerateRoof*.sh3p files under plugin folder
-Download and reinstall v.5.1 and try again
Usually Windows don't overwrite a file but change the name by adding (1), (2)... each time.
If error persist please run SH3D from terminal and put the output here.
User avatar
Post by hansmex »
I deleted all old versions, but... no result - same error message.
I deleted SH3d and installed new version 7.6.1 (with new interface... yuk) - but... no result - same error message.
And uhm... seems v7.6.1 from MS Store breaks half of my plugins.
Good job, Monkeys!
Post Reply New Topic
Who is online
