Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Generate roof plugin » » » » Post: Re: Generate roof plugin |
Print at Sep 9, 2026, 10:02:28 PM |
| Posted by dorin at Sep 27, 2025, 5:53:45 PM |
Re: Generate roof plugin Version 5.1 Downloadable from here or here . Also available through Plugin Manager. and Roof windows library version 0.3 downloadable from here or here . What it can do: -Generate a roof object based on a closed polygon (a SH3D room) -It can make holes for roof windows, provided they are from the specific library -It can generate roofs for buildings with holes, such as inner courtyards. -You could make some overlapping roofs. What it cannot do: -It cannot model an object. It regenerates a new one every time you change a parameter. How it works: -Select a previously created room or roof and execute Tools ->Generate roof... Note: If nothing specific is selected, Generate Roof... is grayed out. It should look like this: ![]() Some explanations: 1. Roof preview. Use the mouse to: - rotate the preview - select current roof face(s): - Ctrl + mouse click -> select different faces -Shift + mouse click -> select a continuous series of faces 2. View panel. Choose the viewpoint and how you see (parallel/perspective) 3. Choose what you want to see in the preview. 4. The roof total visible area. 5. The edges control panel 6. Modify coordinates panel: -Choose Edge or Start point or End point to be modified. -The X, Y, and Z coordinates are marked with the same color as the axes. -Step: set the step value for X, Y, Z spinners. - You can modify the roof geometry, such as roof overhangs, or create overlapping roofs. 7. Add/remove edge. It is active if Edge button is selected. - With „+” will split the edge in two, generating corresponding edges. - With „-” will delete the selected edge 8. Border panel where you can choose between vertical and orthogonal border. -Keep in mind that borders surround the entire roof face. 9. The roof thickness. 10. The roof elevation. Will set also the level elevation. 11. Before saving the roof you could choose to reverse faces for use as a more customizable ceiling. 12. Undo, Redo and Reset button. - Reset will load the initial roof. 13. The author field. It could be modified. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 9, 2026, 10:02:28 PM |
