Total posts in this thread: 339
Posts: 339   Pages: 34   [ Previous Page | 18 19 20 21 22 23 24 25 26 27 | Next Page ]
Previous Thread This topic has been viewed 3074882 times and has 338 replies Next Thread
dorin
Romania
Re: Generate roof plugin
Maybe I've don't understood correctly.
What I want to say is this:
The roof is outside the room (yelow).
Or maybe you refer to point 3.3 from the mini-tutorial where I've explained a possibly use of reverse faces.
For my curiosity: can you share the last roof object?
[Dec 22, 2023, 10:56:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
What I meant was setting an overhang distance for the roof so you don't have to draw a room outside the walls. You simply double-click a room on the wall outside perimeter. Setting an overhang extends the roof to the size of the yellow outline as in your image. It's much easier to change an overhang number and generate a new roof than having to redraw/extend the room itself until you get it right. I thought I saw that in one of the previous versions but I'm probably suffering from CRS again ;)
Here is the latest version of the roof: RoofChallenge.sh3d
[Dec 22, 2023, 11:34:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Probably I misunderstood again.
For this purpose I've made an option in AutoDimensioning plugin, roof projection.
To modify this in 3D not only in 2D I try to do in the future for this plugin.
In AutoDimensioning wasn't simple to identify the exterior walls and set the build area or roof projection.
More than a half of the code is dedicated to this features.
The GenerateRoof it is already huge and I don't think it is useful to make it heavier adding something which already exist and work.
My yellow room is generated in this way. Then you could make fine adjustments even to add/remove points where you need.
[Dec 23, 2023, 8:14:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Ah, I'm not getting crazy after all. I knew I had seen it somewhere laughing
No problem, using the AutoDimensioning plugin is fine, I just just didn't think of doing it that way.
[Dec 23, 2023, 8:52:45 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
stoverpd
FRANCE
Hello,
I discovered your plugin, and tried to use it.
I have a problem because in my home I've a roof with different levels.
So when I draw a piece around the walls, all the elevation sections of roof deck are the same.
How to use the plugin with different level, is it necessary to do many roof or it possible to have one roof with different levels?
Thank you for your return
[Jan 14, 2024, 5:49:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
stoverpd
FRANCE
Link to open the home: https://servimg.artdomi.com/maison2023.sh3d
[Jan 14, 2024, 6:00:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
I like your project! Thanks you share it!
At this moment the plugin can't make roof with edges at different elevations.
I work on this but it's not so simple.
For a multiple levels roof you have to generate multiple roofs.
I've prepared a tutorial for such case because I've needed too.
Is not finished yet but could be used as principle.
Unfortunately is not exactly what you need.
https://www.mediafire.com/file/apcarz1vg63agt...plugin+tutorial3.pdf/file
https://www.mediafire.com/file/mbuc6xlghxpc6cb/Two+levels+roof.sh3d/file
[Jan 14, 2024, 6:41:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
architectech
Sweden
Hi: Thanks for a fantastic job! I downloaded the entire post for study and use.
[Jan 15, 2024, 8:45:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
@stoverpd
Probably your house will look something like this.
Main roof in one piece and a separate roof on the side with swimming pool.
[Jan 16, 2024, 3:05:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
drdraco
Magyarország
I've just intalled the Generate roof plugin, but in the main menu Tools/Generate roof is dimmed so I can not click on it and start using.
I use Win11 and I have the last 7.2 version of SweetHome 3D.
How can I use this plugin?
[Feb 12, 2024, 11:25:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
