Re: Generate roof plugin
Wow, that looks very promising! While you're at it, try to make the border textures to follow the roof line Or even better a selectable texture for each border so you can differ between the horizontal sides and the sloping sides.
Many thanks for the immens effort you are putting into this excellent plugin!
Romania
Considering done! (Thanks to Daniel118 who is the expert)
I think is not better (not now). Imagine a roof with 87 faces, each face with an average of four sides (borders). After you calculate this let me know how long could be the list.
On the other hand, I feel you as a programmer: why not take the source, modify and try your wishes than share it with us?
PS I'm SORRY if I managed to upset you
87 faces is an extreme roof, most will have less faces. Maybe a switch where you choose to generate separate borders or not. That way you can avoid an extremely long list of properties. Personally I would prefer a long list if it gives me the posibility to fine-tune the look of a roof.
I am a (professional) programmer but mainly in C# (on Linux). I'm currenty very busy but I'll see if I can make some sense of Java The syntax is apparently very similar to C# so a quick understanding of what is what should be easy.
Pakistan
the plugin "generate roof" is not displayed in tools menu in sweet home 3d version 5.3, 5.4 it works in newer versions. what is the method to work it in older versions plz guide me
Why wouldn’t you upgrade your version of Sweet Home 3D ? That would be the easiest solution.
Canada
@Daniels118
@crackwood01 We are far from having a "black and white" view from the side, however you can now have a textured side view where you can draw dimension lines. To do this, you can exploit the new feature of the Pan 3D view plugin which enables the parallel projection in 3D view (CTRL+J) and allows to align the camera to the selected object (CTRL+K). You can then add vertical dimension lines using the 3D dimension lines plugin with the help of a "tracing paper" (i.e. a transparent object where you can draw the dimension lines.) You can download a tracing paper model of 10x5 meters from here.
The terrain generator plug-in has a built-in wireframe option, i mean, when i use revit i can switch from wireframe to hiddenline.
could this be a starting point to get a 2d blackandwhite elevation view
Italy
@crackwood01 The Pan3dView plugin already has this option, you can find it under the menu 3D view -> Pan 3D view settings. The option is named "Outline" and you have 4 choices: - none - perspective - parallel projection - both
But please note that wireframe is not the same of a technical drawing.
