Print at Sep 23, 2026, 8:33:45 PM
Posted by crackwood01 at Aug 14, 2023, 7:04:28 AM
Re: Generate roof plugin
@Daniels118
@crackwood01
We are far from having a "black and white" view from the side, however you can now have a textured side view where you can draw dimension lines. To do this, you can exploit the new feature of the Pan 3D view plugin which enables the parallel projection in 3D view (CTRL+J) and allows to align the camera to the selected object (CTRL+K).
You can then add vertical dimension lines using the 3D dimension lines plugin with the help of a "tracing paper" (i.e. a transparent object where you can draw the dimension lines.)
You can download a tracing paper model of 10x5 meters from here.
The terrain generator plug-in has a built-in wireframe option, i mean, when i use revit i can switch from wireframe to hiddenline.
could this be a starting point to get a 2d blackandwhite elevation view
