Italia
Re: Generate roof plugin
this project is making me hungry of development... I managed to buy a new PC at home, so when I'll have it setup I'll try to download the code and check if I can understand. You'll tell me if my help is fine or not, but at least I'll try to understand the code! Great work to all!
Italy
@crackwood01 We are far from having a "black and white" view from the side, however you can now have a textured side view where you can draw dimension lines. To do this, you can exploit the new feature of the Pan 3D view plugin which enables the parallel projection in 3D view (CTRL+J) and allows to align the camera to the selected object (CTRL+K). You can then add vertical dimension lines using the 3D dimension lines plugin with the help of a "tracing paper" (i.e. a transparent object where you can draw the dimension lines.) You can download a tracing paper model of 10x5 meters from here.
Italy
You may use this method. From my experience it works only for error messages, not normal output (any try to redirect the stdout failed). It should be enough for most cases, however if it shouldn't be so, you may try this method.
Canada
Thank you,
this is the log.txt content after trying to run he roof generator plugin
DynamicPluginLoader: plugin.classpath property not set DynamicPluginLoader: plugin.classpath property not set DynamicPluginLoader: plugin.classpath property not set DynamicPluginLoader: plugin.classpath property not set DynamicPluginLoader: plugin.classpath property not set Object3DBranchFactory replaced with ExtensibleObject3DFactory DimensionLineEx3DFactory added successfully Top camera polyline listener removed! Wiring3DFactory added successfully Checking for updates... Sending usage information... Top camera polyline listener removed! View3DEnhancer installed successfully! Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: (minimum <= value <= maximum) is false at java.desktop/javax.swing.SpinnerNumberModel.<init>(SpinnerNumberModel.java:139) at com.eteks.sweethome3d.swing.NullableSpinner$NullableSpinnerNumberModel.<init>(Unknown Source) at com.eteks.sweethome3d.swing.NullableSpinner$NullableSpinnerLengthModel.<init>(Unknown Source) at generateroof.GenerateRoofPlugin.createComponents(GenerateRoofPlugin.java:1148) at generateroof.GenerateRoofPlugin.generateNewRoof(GenerateRoofPlugin.java:439) at generateroof.GenerateRoofPlugin.generateRoof(GenerateRoofPlugin.java:278) at generateroof.GenerateRoofAction.execute(GenerateRoofAction.java:31) at it.ld.sh3d.devtoolkit.DynamicAction.execute(DynamicAction.java:62) at com.eteks.sweethome3d.swing.HomePane$ActionAdapter.actionPerformed(Unknown Source) at com.eteks.sweethome3d.swing.ResourceAction$AbstractDecoratedAction.actionPerformed(Unknown Source) at java.desktop/javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1967) at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2308) at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:405) at java.desktop/javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:262) at java.desktop/javax.swing.AbstractButton.doClick(AbstractButton.java:369) at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:1020) at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI$Handler.menuDragMouseReleased(BasicMenuItemUI.java:1132) at java.desktop/javax.swing.JMenuItem.fireMenuDragMouseReleased(JMenuItem.java:575) at java.desktop/javax.swing.JMenuItem.processMenuDragMouseEvent(JMenuItem.java:472) at java.desktop/javax.swing.JMenuItem.processMouseEvent(JMenuItem.java:417) at java.desktop/javax.swing.MenuSelectionManager.processMouseEvent(MenuSelectionManager.java:342) at java.desktop/javax.swing.plaf.basic.BasicPopupMenuUI$MouseGrabber.eventDispatched(BasicPopupMenuUI.java:903) at java.desktop/java.awt.Toolkit$SelectiveAWTEventListener.eventDispatched(Toolkit.java:2194) at java.desktop/java.awt.Toolkit$ToolkitEventMulticaster.eventDispatched(Toolkit.java:2086) at java.desktop/java.awt.Toolkit$ToolkitEventMulticaster.eventDispatched(Toolkit.java:2085) at java.desktop/java.awt.Toolkit$ToolkitEventMulticaster.eventDispatched(Toolkit.java:2085) at java.desktop/java.awt.Toolkit.notifyAWTEventListeners(Toolkit.java:2042) at java.desktop/java.awt.Component.dispatchEventImpl(Component.java:4917) at java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2321) at java.desktop/java.awt.Component.dispatchEvent(Component.java:4843) at java.desktop/java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4918) at java.desktop/java.awt.LightweightDispatcher.processMouseEvent(Container.java:4547) at java.desktop/java.awt.LightweightDispatcher.dispatchEvent(Container.java:4488) at java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2307) at java.desktop/java.awt.Window.dispatchEventImpl(Window.java:2772) at java.desktop/java.awt.Component.dispatchEvent(Component.java:4843) at java.desktop/java.awt.EventQueue.dispatchEventImpl(EventQueue.java:772) at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:721) at java.desktop/java.awt.EventQueue$4.run(EventQueue.java:715) at java.base/java.security.AccessController.doPrivileged(Native Method) at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:85) at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:95) at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:745) at java.desktop/java.awt.EventQueue$5.run(EventQueue.java:743) at java.base/java.security.AccessController.doPrivileged(Native Method) at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:85) at java.desktop/java.awt.EventQueue.dispatchEvent(EventQueue.java:742) at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:203) at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:124) at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:113) at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:109) at java.desktop/java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101) at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90)
Romania
@crackwood01 Finlay I've found one of the combination of setting to reproduce this error. Now I'll try to fix it! It's something with unit measurement (Inch, foot etc). Thanks to report it.
Italy
@crackwood01 This is a bug of version 4.0.beta2, it only happens if you are using the imperial system. You may switch to the metric system or downgrade to the latest stable version.
@Dorin The thickness is initialized to 10 cm, but when imperial system is used the minimum value is set to 1 foot = 30 cm, which is greater than the value, causing the exception. Maybe the minimum should be 1/4 foot (3 inches).
EDIT: we wrote at the same time!
[Edit 1 times,
last edit by Daniels118 at Dec 28, 2022, 5:22:11 PM]
Romania
Looking on multiplier plugin, I think I found a solution. Very soon will be an update. Until that, the Daniels118 solution, is good for an workaround. Thanks again!
