Total posts in this thread: 4
Previous Thread This topic has been viewed 13916 times and has 3 replies Next Thread
gandalf
Light sources
First of all, thank you for the soft! I'm using it for 3 months now to plan my apt and it saves me a lot of work and makes my project more real :)
The only problem I have is with light sources. I'm working a lot on the concept of wall colors and the current settings are making it hardly usable.
Basically, my walls are 240cm tall, and I want it to keep ratio to analyze how the colors will look, but with walls at 240cm, the light source is too low and majority of the apt (which is quite small I admit - 50m2) is in the shadow.
I read while searching for the topic on this site that there should be a separate light source per each room, but I don't have it on my images and I miss it a lot :)
Examples of what it looks like (yes, I have multiple rooms inside)
- http://img91.imageshack.us/img91/816/zgoda2october.png
- http://img91.imageshack.us/img91/884/zgoda2october2.png
- http://www.uploadgeek.com/share-35E8_4AD769E7.html
I can see several solutions to this:
* Ability to "switch off" lighting and just see everything without shadows in full colors
* Add "luminescence" as an ability for furniture (that would be awesome!)
* Add more lights and put them around (like in blender)
* Move the default "light" source above the apt, very high.
[Oct 15, 2009, 9:59:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
MarcSc
Re: Light sources
Additonally to this, It would be nice to have an option to tell where the major light source is located, e.g. the Sun.
Or the possibility to rotate all marked objects by 90° clockwise and counterclockwise.
Currently I must see that the rendered light is not coming from the side it is usually coming in reality in my flat.
I understand that this very much leads to 3D export for post treatment with other renderers wink
[Nov 8, 2009, 4:52:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Light sources
Try the Home Rotator Plug-in developed by Michel Mbem. Read also the end of the user's guide for more information about plug-ins .
[Nov 9, 2009, 8:26:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
MarcSc
Re: Light sources
Perfect smile
That was a little bit like "RTFM" but much nicer cool
Thank you smile
[Nov 9, 2009, 10:20:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
