Total posts in this thread: 50
Posts: 50   Pages: 5   [ Previous Page | 1 2 3 4 5 | Next Page ]
Previous Thread This topic has been viewed 1159529 times and has 49 replies Next Thread
dmcclurg
United States
Re: Side view plug-in
Much appreciated! Elevations are key to submitting to understanding a design. I like the flexible way you implemented this
[Apr 5, 2021, 4:15:22 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thank you all for your feedback. I’m glad you like this plug-in smile
[Apr 5, 2021, 9:55:37 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
YGYL
Wish for many years of function. Thank you very much.
It's tested. It works
[Apr 5, 2021, 10:11:49 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I combined this great new plugin with OKH ideas published in this old thread to realize this image.
The aim was to be able to add some dimension lines on side views of the house available in the demo #8, which I slightly changed.
With the plugin, I created two side views of the house in .png files, that I reimported in two new designs with the Plan > Import background image tool.
At the second step of the Background image wizard, I entered the main dimension of the house.
Then, in the Plan, I added some horizontal and vertical dimension lines with the Create dimensions tool. I had to increase the size of the dimension numbers.
In File > Page Set up dialog box, I only selected Print Plan and printed the plan in a PDF file.
I repeated this process for the second side view and finally, I neatly assembled the two images in an image processing piece of software to get the final image.
[May 17, 2021, 5:50:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
@Veronique
Dapper attempt to add dimensions to a sideview. But honestly, what we need is something as easy as Dorin's auto-dimensioning plugin.
[May 18, 2021, 11:08:17 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
bitacovir
applause Re: Side view plug-in
applause applause applause applause applause applause
Thank you very much for this plugin. For many years I consider Sweet Home 3D has a limited development, because it kept the same deliverables: Image of a Plan View and 3D renders. Now we have a more complete software. As an architect, I have used SH3D for concept design and sketching. Elevation views are a good complement to deliver a full presentation of an design idea, during the early design stage of a project.
I hope you can keep improving this plugin.
Regards.
PD: SweetHome3D is recommended for the OSArch Community https://wiki.osarch.org/index.php?title=AEC_Free_Software_directory
[May 18, 2021, 6:54:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Gildaniel
Russia
YAHOOOOO!!!!! love struck
[May 24, 2021, 10:58:55 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Gildaniel
Russia
It would be great to show inner views also, wall in the room; and put dimensions to view without exporting/importing procedure
[May 24, 2021, 11:32:09 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Good start for this plug-in.
Add perhaps an option which be to add the background of the original picture.
wink
[May 27, 2021, 8:22:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
bdom
un super outil pour la dépose des permis mais pas évident à appréhender
petit plus indispensable
- soit un petit point d'interrogation avec une aide contextuelle
- soit modifier la note au dessus
le menu vue 3D/modifier visiteur virtuel/double clic sur caméra/modifier angle du corps 0°, 90°, 180° ou 270°
- soit modifier l'angle dans la fenêtre
dans l'idéal
en plus du bouton enregistrer un bouton EDITER
- soit exportation et réimportation directe
- soit ouverture dans une mini appli basique pour des cotes et du texte
c"est génial mais pour l'instant limité aux experts
possibilité aussi de basculer dans cette vue avec un icône ( une image d'un coté de maison ) placé à doté des 4 flèches vertes de la vue 3D
avec bien sûr possibilité d'ajout de mesures
avec ce plug in je ne vais plus avoir à faire 5 plans différents pour les déposes de permis de la famille et des amis.
mais je pense à ceux qui ne maitrisent par exportation et réimportation en image arrière plan comme moi il y a peu
encore merci
mac mini 2020 plan technique plus que déco
[Sep 6, 2021, 9:15:39 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
