Total posts in this thread: 50
Posts: 50   Pages: 5   [ Previous Page | 1 2 3 4 5 | Next Page ]
Previous Thread This topic has been viewed 1159510 times and has 49 replies Next Thread
Alex3D
Re: Side view plug-in
Very good !
Just missing the dimension lines (fr: "cotes") for being complete.
I know that there are workarounds, but it is quite complex (for me).
Thanks
[Oct 24, 2021, 6:52:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
YGYL
It is recommended to change the background color. Or can read the sky texture
The wall is white, the sky is also white, you can not see the wall
[Dec 7, 2021, 4:02:36 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
krchel
This is a good plugin, thank you!
[Jan 31, 2022, 7:39:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
svDemara
Brilliant plugin. Merci.
I'm a newbie so there's probably a way I've not yet learned but I can't get it to include Daniels118's wiring product. Would be useful.
Also dimensions as mentioned.
[Feb 5, 2022, 12:36:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
@svDemara
At this time wirings and 3D dimension lines are only supported within the 3D view.
My plan is to create an evolution of the side view plugin that will automatically develop all the walls of a room to a single sheet. This plugin will also support wirings and 3D dimension lines.
[Feb 6, 2022, 11:04:56 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
@Puybaret
I think that initializing HomeComponent3DParallelProjection with the Object3DFactory instance used in the 3D view (instead of creating a new one) could be enough to make wirings and 3D dimension lines visible in the side view too.
[Feb 6, 2022, 11:58:52 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I had a look yesterday and wanted to try the same thing, but the factory is private. I know how to access private fields but don't want to use this part of Java and prefer to add an accessor in a coming version.
[Edit 1 times, last edit by Puybaret at Feb 6, 2022, 1:41:48 PM]
[Feb 6, 2022, 1:39:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
Adding an accessor would be great! Another great improvement would be to make the Object3DFactory extensible so that plugins can add their implementation instead of replacing it, so that multiple plugins can work together (which is how my 2 plugins actually work).
[Feb 6, 2022, 2:25:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Marcelmacaire
Gabon
Merci aux concepteurs de ce logiciel, ainsi qu'aux contributeurs. Et bravo pour cette aide de Veroniq pour réaliser des plans de coupe A-A, ou B-B.
Je m'en sors plutôt bien avec sweet home 3d. Mais, je souhaiterais justement des améliorations sur la possibilité de créer des plans de coupe. D'autre part, au lieu de lister le mobilier d'un projet, il serait bien d'indiquer les matériaux utilisés pour réaliser un mur (le nombre de parpaings par exemple).
C'est peut-être trop demander, mais ça nous fidéliserait à notre logiciel plutôt que d'aller vers d'autres programmes assez difficiles à utiliser.
Encore félicitations pour cette merveille d'application !
[Mar 26, 2023, 1:43:24 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Marcelmacaire
Gabon
Merci pour cette précision. Je télécharge immédiatement ce plugin.
Encore bravo pour tous ces efforts pour améliorer sweet home 3d.
[Mar 30, 2023, 4:57:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
