Total posts in this thread: 50
Posts: 50   Pages: 5   [ Previous Page | 1 2 3 4 5 | Next Page ]
Previous Thread This topic has been viewed 46130 times and has 49 replies Next Thread
Re: Freezing in SH3D and Furniture Editor importing models
Could you report if furniture import works when the 3D model doesn't contain any texture image?
[Apr 1, 2021, 6:31:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
henrisson
United States
Yes, same result with the simplest object and no texture (uploaded here for reference)
[Apr 2, 2021, 4:26:55 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dvi
Germany
Hey guys, I have the same issue and was wondering if there is any fix or any workaround for this?
[Apr 11, 2021, 12:44:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
henrisson
United States
Re-reading your question: the question was "does furniture import works" with simple objects, and my answer should read "No, it still crashes with simple objects", that probably wasn't super clear.
[Apr 18, 2021, 10:50:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sb0373
Germany
Can you please confirm whether the issue is "freezing" or "crashing"?
I am experiencing the latter without freezing on CentOS8.
[Apr 24, 2021, 1:58:45 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I just created another version 6.5.2 based on Java 15 and JOGL 2.3.2 available here (68 MB). It will run with Rosetta 2 with Mac M1 but as some of you have problems with Mac Intel too, it could worth a try to check if the issue you encountered comes from the change of Java or JOGL versions.
[Apr 27, 2021, 10:32:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
henrisson
United States
Looks like it's working for me (Intel Mac). Thanks!!!
[Apr 29, 2021, 2:02:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Thanks for your test. So the problem probably comes from JOGL 2.4.0 or the way to use it.
Could you also try the version 6.5.2a [edit: removed link] where I made a small change (this version will run natively on Mac M1)?
Hope to read the results of the tests of other users too. Please, give some feedback because I still didn't find any way to reproduce this issue.
[Edit 1 times, last edit by Puybaret at Aug 10, 2022, 11:53:51 AM]
[Apr 30, 2021, 4:19:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
henrisson
United States
6.5.2a crashes on furniture import.
[May 2, 2021, 5:22:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sb0373
Germany
Same for CentOS 8.
$ /opt/SweetHome3D/SweetHome3D-Java3D-1_5_2
Java 3D: implicit antialiasing enabled
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007fc37e3c0ee9, pid=121542, tid=0x00007fc35a3be700
# JRE version: Java(TM) SE Runtime Environment (8.0_202-b08) (build 1.8.0_202-b08)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.202-b08 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# C [libawt_xawt.so+0x45ee9] ReadRegionsInList.constprop.5+0x4e9
# Core dump written. Default location: /opt/core or core.121542
# An error report file with more information is saved as:
# /tmp/hs_err_pid121542.log
Importing a furniture library works. Importing just a furniture piece fauls.
[May 5, 2021, 6:06:30 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
