Previous Thread This topic has been viewed 6264 times and has 2 replies Next Thread
treehousenorris2
United States
Compiling Textures Library Editor
Hello,
I was able to build the Furniture Library Editor using JDK 8 for the SweetHome project jre and the Furniture Editor project jre and the Ant runtime configuration jre, and xml target=1.5.
Now when trying to build the jarExecutable of the Textures Library Editor (with the above java versions) I'm getting a java.awt.desktop package does not exist error, and I see that the Textures Editor README says to use JDK 5 or 6 to build.
The Ant runtime configuration jre says "JRE version less than 1.8 is not supported", and though I changed the Texture Editor and SweetHome project jres from JDK 8 to 5, I am still getting the same error, as seen below.
Some more information on the required desktop version or the SweetHome project version would be helpful. Thank you!
[Feb 5, 2021, 8:58:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Compiling Textures Library Editor
In build.xml of Textures Library Editor, you should add the line:
<pathelement location="../SweetHome3D/libtest/javaAwtDesktop.jar"/>
under the line:
<pathelement location="../SweetHome3D/libtest/jnlp.jar"/>
or build the project with Sweet Home 3D 6.1 source code as suggested in README.TXT.
[Feb 5, 2021, 10:23:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
treehousenorris2
United States
Awesome, adding the path element worked. Thank you!
[Feb 15, 2021, 6:28:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
