Previous Thread This topic has been viewed 2862 times and has 2 replies Next Thread
HdFeX47
Brazil
How to Render with Flat Colors, like a Material ID?
Is there a way to render materials or objects just in flat colors, like in Sketchup (image below), so i can use the magic wand selection in a image editor software?
The reason i want to do this is to make post-processing easier in complex scenes.
Thx!
[Jan 21, 2021, 8:52:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How to Render with Flat Colors, like a Material ID?
You could try this:
- select all in your home
- export the selection to OBJ format
- edit the MTL file where you'll change the number following illum by 0 to get lines illum 0
- import the exported OBJ file as a piece of furniture in a new Sweet Home 3D project
- go to the point of view you want and create a photo
[Jan 22, 2021, 10:29:26 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
HdFeX47
Brazil
applause Re: How to Render with Flat Colors, like a Material ID?
You could try this:
Thank you. I also had to also change the materials to just flat colors to make it exactly like the image, if any one tries to do the same. Also, to not lose your project by changing all the materials, just save as a new one and do those steps. After that, the masks works like a charm.
[Jan 23, 2021, 8:16:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
