Previous Thread This topic has been viewed 5062 times and has 2 replies Next Thread
paolocesari
Floor shadow on the ceiling
after creating a model with some levels, on 3D view I've found the floor shadow on the ceiling.
Here the some examples:
And my levels:
How can I solve the problem?
Thanks to all!
[Note from moderator: fixed links to images, be sure to use "Direct Link" option]
[Edit 1 times, last edit by Puybaret at Jan 6, 2021, 5:25:38 PM]
[Jan 6, 2021, 8:05:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Floor shadow on the ceiling
This must be the ceiling of some rooms. The height of a level is used to compute the elevation of ceilings and you should enter the height of the level, not the altitude of the ceilings.
So I guess the last column of your level modification dialog box should rather display 320.
[Jan 6, 2021, 5:38:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
paolocesari
I'm really stupid, as you say the height of the rooms should be set at 320 cm.
Problem solved, thank you very much!
[Jan 7, 2021, 6:01:20 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
