Romania
Re: Polylines
@1. -Install AdvancedEditing plugin; -Select the polyline; -Edit points... -New (on bottom left).
@2. To have the length I use HORIZONTAL cylinder, export to CSV then in Calc or Excel make the sum; I use this also for pipes. NOTE: the cylinder MUST be horizontal in library to keep the correct length in any position or angle.
@3. Read @1 & @2. Good luck and patience!
Germany
Re: Polylines
Hello, I just tried to add points to an existing polyline but I can't find the menu item "Edit points" when I have a polyline selected. I have the AdvancedEditing plugin installed. What do I wrong?
Germany
Re: Polylines
I just found the solution; The "Edit points" menu item does not appear in the right mouse button menu but only if you have a polyline selected under Plan main menu item. Hope this clarification helps other users too.
