Total posts in this thread: 5
Previous Thread This topic has been viewed 6120 times and has 4 replies Next Thread
August_Bebel
Russia
confused Polylines
Hello there!
I'm trying to use Polylines to lay out the electric cables though the apartment and I'm having some… questions.
1. How do I add points to the already existing polyline? I just can't find how to do it or it's not possible? (Example what I need below)
2. How to measure the total length of the polyline? Only manually?
3. Maybe there are better ways to do electric cables in the program which I'm not aware of? Or some plugins help with that?
[Jun 15, 2020, 10:10:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Polylines
In your case, I would use very thin walls...
[Jun 17, 2020, 10:17:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Re: Polylines
@1. -Install AdvancedEditing plugin;
-Select the polyline;
-Edit points...
-New (on bottom left).
@2. To have the length I use HORIZONTAL cylinder, export to CSV then in Calc or Excel make the sum;
I use this also for pipes.
NOTE: the cylinder MUST be horizontal in library to keep the correct length in any position or angle.
@3. Read @1 & @2.
Good luck and patience!
[Jun 18, 2020, 6:40:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
harryth
Germany
Re: Polylines
Hello,
I just tried to add points to an existing polyline but I can't find the menu item "Edit points" when I have a polyline selected.
I have the AdvancedEditing plugin installed.
What do I wrong?
Thanks and
Best Regards
Harald
[Oct 28, 2020, 8:08:08 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
harryth
Germany
Re: Polylines
I just found the solution;
The "Edit points" menu item does not appear in the right mouse button menu but only if you have a polyline selected under Plan main menu item.
Hope this clarification helps other users too.
BR
Harald
[Oct 28, 2020, 8:30:45 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
