Total posts in this thread: 4
Previous Thread This topic has been viewed 3057 times and has 3 replies Next Thread
stain35
Rooms out of shape after many wall changes
Having done numerous changes in my first project, including recreating walls to ensure different levels are aligned correctly, most of my room shapes are slightly misshaped in relation to the walls.
I realise that double clicking in rooms will create the correct shape. However, I have done so much work on my current rooms that I want to alter the shape to fit finalised walls. Attempting this manually by moving points is not great as many extra points have appeared over time. Is there any way of auto-reshaping rooms?
Cheers
Mark
[Jun 14, 2020, 12:26:04 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
stain35
Re: Rooms out of shape after many wall changes
I meant to write "I realise that double clicking in walls"
[Jun 14, 2020, 12:26:59 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
If, for some reason, you cannot simply delete the room and then recreate a room that match's your walls automatically, you can left click on you room > right click near each of the points you do not require and from the drop down menu delete point
[Jun 14, 2020, 11:00:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
stain35
Thanks. Deleting points was useful (not done that before) and also did not realise that either double clicking mis-aligned corner points or dragging would automatically re-align with existing walls. Much neater now thanks.
[Jun 19, 2020, 7:55:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
