Total posts in this thread: 4
Previous Thread This topic has been viewed 1309 times and has 3 replies Next Thread
Bill_L
How to make the color and shape look the same
Hi, everyone, I am trying to use the software to create a set of pictures for my visual search experiment. I want the distractors to have the same shape but different color or have the same color but different shape as the target.
For the shape, I don't need the same shape/different color to be exactly the same shape, I only need it to look the same size as the target.
But due to the distance and lighting, I can't have the same shape or same color unless I use my owe eye to adjust it.
I attach a picture to illustrate, the tablet in the red rectangular is the target and the two frames in the black are the distractors.
Any suggestions about how I canget the same shape/color in a more systematic way, so I don't have to writhe "use my own eye" in my paper? Thanks in advance.
[Jun 8, 2020, 3:56:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How to make the color and shape look the same
If you don’t want that the lights of the scene alters the color of an object, you could use a 3D model at OBJ format with an associated MTL file containing materials with an illum 0 setting. See this thread for some examples (even if that thread is about how to make glowing lights with ray tracing renderers).
[Jun 10, 2020, 7:06:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
And about the fixed shapes, it’s not possible to avoid the resizing / deforming / hiding effect of the perspective projection.
Using OBJ spheres with an illum 0 setting could avoid the deforming effect (you would get a disc with a fixed color) but it still could be more or less large at screen according to its distance to the camera and possibly hidden by other objects in front of it.
[Jun 10, 2020, 7:19:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Bill_L
Thank you. I will try to use the .obj format
[Jun 12, 2020, 3:45:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
