Search for my new project (lounge) luminous neon objects from American bars. I couldn't find anything in 3D Warehouse!
Is there a website that has something like this?
Thank you very much!
Merry Christmas & Happy New Year
Engelbert
Well, rather an appendix to the SVG mini guide. But with little detail, it does not describe how to add multiple light-sources one model. However, in the Forum there is good advice in several places - also how you can place lights manually in the SH3D plan. That said, for a neon light, my off the cuff advice to avoid too many complications, would be to use a model with a box and transparent lettering so you can place the lights behind the transparent parts in the box.OKH hat eine Anleitung geschrieben wie man das macht.
Yes, you may have a hard time both finding old bar neon lights and adding lightsources to make it look real. A lot of time and lots of try and fail. I know I would.But it's going to be long ...
Yes, well, for you, I suppose... Not sure about me. But then, everything is simple when you know how [:)]. Anyway, thanks again, most useful. New possibilities for learning... And Merry Hols. okThis is really very simple...
Amazing. [=D>]This is really very simple.
More useful example (i hope):
Create your own sign using walls, floors and other objects (furniture).
(If you want your floor to have thickness create next level with elevation>0)
Apply different colors to parts of your sign (for walls - top and both sides).
Select all parts* and Export to OBJ.
Modify .mtl - illum to "0" (You can remove some parameters - i think you can leave only newmtl, illum and Kd).
Import .obj - rotate, change size if needed, etc.
Place in your home and render Q4 (or with plugin - set gI to "path")**
*If you want to cut hole in floor draw smaller floor shape inside(on it) and don't select it for exporting (see "O" in "GLOW")
** No glowing when sky has texture
Download glow.sh3d
