Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: SAVING RENDER SETTINGS AUTOMATIC |
| Print at Oct 10, 2026, 4:53:57 PM | |
| Posted by mostafanasr at Dec 29, 2019, 4:03:54 PM |
SAVING RENDER SETTINGS AUTOMATIC When i try to render my sweethome 3d i try different settings at Q3 and Q4 every time i save the resulted photo that is good But i must record the settings every time even in photo name. is there way to SAVING RENDER SETTINGS AUTOMATIC to return to it again. thank you very much for this excellent application. |
| Posted by enkonyito at Dec 30, 2019, 10:27:57 PM |
Re: SAVING RENDER SETTINGS AUTOMATIC Hi mostafa, Whether with the AdvancedSettings_PhotoRendering-1.3.1 plug-in or the Rendering properties action of the PhotoVideoRendering-1.8 plug-in, the rendering settings of a project are saved after modification. For a new project, the plug-ins find either the default values or the custom values in a file for the installer version of Sweet Home 3D. You will find more information in this document. Enko ---------------------------------------- EnkoNyito |
| Posted by mostafanasr at Jan 4, 2020, 12:00:46 PM |
Re: SAVING RENDER SETTINGS AUTOMATIC Hi enkonyito, first, thank you for your answer. i need text file for render settings show me all settings i used for every render. |
| Posted by enkonyito at Jan 5, 2020, 12:25:30 AM |
Re: SAVING RENDER SETTINGS AUTOMATIC i need text file for render settings show me all settings i used for every render. To know which file to edit according to your system, refer to this FAQ on increasing memory. Regarding the rendering settings, just add -Dcom.eteks.sweethome3d.j3d.PhotoRenderer. in front of the properties of this file by modifying the default values. (lowQuality: Q3; highQuality: Q4) ---------------------------------------- EnkoNyito |
| Posted by mostafanasr at Jun 10, 2020, 8:09:46 PM |
Re: SAVING RENDER SETTINGS AUTOMATIC thanks enkonyito, i will try it |
| Posted by mostafanasr at Jun 10, 2020, 8:11:41 PM |
Current timezone is GMT Oct 10, 2026, 4:53:57 PM |
