Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Photo rendering shows bad image quality |
| Print at Sep 20, 2026, 10:04:34 PM | View all posts in this thread on one page |
| Posted by MichaelN at Sep 15, 2019, 6:36:26 PM |
Photo rendering shows bad image quality Why I see such noisy pictures after rendering in quality level 3? https://we.tl/t-Bgvulpet77 |
| Posted by hansmex at Sep 16, 2019, 3:26:23 PM |
Re: Photo rendering shows bad image quality If you don't like it, did you try Q4 ?? As an alternative, you could try Enkonyito's plugin, in which you can "play" with the settings to get excellent quality. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by MichaelN at Sep 16, 2019, 6:37:53 PM |
Re: Photo rendering shows bad image quality On Q4 is Image quality a little bit better, but also not "clear". And it last much longer. So, for Q3 this noisy picture is the quality I could expect? |
| Posted by VeroniQ at Sep 16, 2019, 8:24:47 PM |
Re: Photo rendering shows bad image quality You may try also this new plugin or follow also some of these tips. |
| Posted by Ceciliabr at Sep 18, 2019, 5:46:13 PM |
Re: Photo rendering shows bad image quality So, for Q3 this noisy picture is the quality I could expect? YES! To get a high quality rendering with a CPU-renderer, you have to be patient. Your CPU determines the rendering speed, and the time needed to perform a quality rendering will be more or less equal when producing the same quality image – no matter what CPU based renderer you choose. A high quality rendering may take several hours, maybe even days. Cec |
Current timezone is GMT Sep 20, 2026, 10:04:34 PM |
