Print at Jul 22, 2026, 12:09:57 AM
Posted by enkonyito at Jun 3, 2019, 2:18:30 AM
Additional Sunflow options (tests)
Sunflow has command line options to control the rendering result without the GUI.
The goal here is to test their actions in Sweet Home 3D.
* Option:
-threads X
Allows you to force the number of threads used for rendering (BucketRenderer, MultipassRenderer).
Default value: number of available processors.
SH3D implementation:
int threads = X;
this.sunflow.parameter("threads", threads);
this.sunflow.options(SunflowAPI.DEFAULT_OPTIONS);
No major differences in rendering time if the number of virtual threads is greater than the number of actual threads available.
* Options:
-lopri
-hipri
Allows you to set the priority of the threads.
Default value: lowPriority = true.
boolean lowPriority = true;
this.sunflow.parameter("threads.lowPriority", !lowPriority);
No major differences in rendering time.
EnkoNyito
Posted by enkonyito at Jun 4, 2019, 6:32:09 AM
Re: Additional Sunflow options (tests)
* Option:
-showaa
Display sampling levels per pixel for bucket renderer.
Default value: showAA = false.
boolean showAA = false;
this.sunflow.parameter("aa.display", !showAA);
showAA = true
showAA = false
EnkoNyito
Posted by enkonyito at Jun 5, 2019, 2:01:32 AM
* Options:
-quick_uvs : Renders the UVs of objects.
-quick_normals : Renders the normals of objects.
-quick_id : Renders using a unique color for each instance.
-quick_prims : Renders using a unique color for each primitive.
-quick_gray : Renders all the objects in the scene gray diffuse, overriding all shaders.
-quick_wire : Renders objects as wireframe.
-quick_ambocc X : Renders a scene in ambient occlusion mode with a certain distance (X).
Only one override shader at a time can be used.
String shaderOverride = null; // "show_uvs","show_normals","show_instance_id","show_primitive_id","quick_gray","wireframe","ambient_occlusion"
if (shaderOverride.equals("ambient_occlusion")) {
float maxDist = 200f;
this.sunflow.parameter("maxdist", maxDist);
this.sunflow.shader("cmdline_override", shaderOverride);
this.sunflow.parameter("override.shader", "cmdline_override");
shaderOverride != null
EnkoNyito
Posted by VeroniQ at Jun 5, 2019, 2:38:18 PM
Nice renderings!
Posted by enkonyito at Jun 5, 2019, 6:36:46 PM
Nice renderings!
Thank you VeroniQ!
I take the opportunity to propose a small survey.
Among the new rendering options, which ones do you find most interesting?
A: show_uvs
B: show_normals
C: show_instance_id
D: show_primitive_id
E: quick_gray
F: wireframe
G: ambient_occlusion (X)
EnkoNyito
Posted by VeroniQ at Jun 5, 2019, 7:42:34 PM
I like E: Quick Grey but the colored ones (especially C and D) are fun!
Posted by ndorigatti at Jun 5, 2019, 9:42:35 PM
quick gray, wireframe and ambient occlusion (E F G)
Posted by enkonyito at Jul 1, 2019, 5:45:02 AM
The additional Sunflow options plug-in will be available with the new version of the photo-video plug-in.
Enko
EnkoNyito
Posted by williamcm at Aug 5, 2019, 3:33:03 AM
Hello hello community
how to install SunFlow
I would like to improve my rendering and how to use it? i have already downloaded but there is no executable file
Thank you william from Cameroon
Hello bonjour la communaute
comment installer SunFlow
je voudrais ameliore mes rendue et comment l utiliser? j ai telecharger deja mais il ya pas de fichier executable
Merci william depuis le cameroun
Posted by enkonyito at Aug 5, 2019, 7:20:22 PM
Hi William!
You can download the precompiled version Sunflow-v0.07.2 and run the sunflow.jar file directly or sunflow.bat after editing.
You can also download the latest version Sunflow-v0.07.3 and follow the build instructions of the README file.
Enko Nyito
EnkoNyito
