Print at Jul 21, 2026, 11:02:05 PM
Posted by enkonyito at Jun 3, 2019, 2:18:30 AM
Additional Sunflow options (tests)
Sunflow has command line options to control the rendering result without the GUI.
The goal here is to test their actions in Sweet Home 3D.
* Option:
-threads X
Allows you to force the number of threads used for rendering (BucketRenderer, MultipassRenderer).
Default value: number of available processors.
SH3D implementation:
int threads = X;
this.sunflow.parameter("threads", threads);
this.sunflow.options(SunflowAPI.DEFAULT_OPTIONS);
No major differences in rendering time if the number of virtual threads is greater than the number of actual threads available.
* Options:
-lopri
-hipri
Allows you to set the priority of the threads.
Default value: lowPriority = true.
boolean lowPriority = true;
this.sunflow.parameter("threads.lowPriority", !lowPriority);
No major differences in rendering time.
EnkoNyito
Posted by enkonyito at Jun 4, 2019, 6:32:09 AM
Re: Additional Sunflow options (tests)
* Option:
-showaa
Display sampling levels per pixel for bucket renderer.
Default value: showAA = false.
boolean showAA = false;
this.sunflow.parameter("aa.display", !showAA);
showAA = true
showAA = false
EnkoNyito
Posted by enkonyito at Jun 5, 2019, 2:01:32 AM
* Options:
-quick_uvs : Renders the UVs of objects.
-quick_normals : Renders the normals of objects.
-quick_id : Renders using a unique color for each instance.
-quick_prims : Renders using a unique color for each primitive.
-quick_gray : Renders all the objects in the scene gray diffuse, overriding all shaders.
-quick_wire : Renders objects as wireframe.
-quick_ambocc X : Renders a scene in ambient occlusion mode with a certain distance (X).
Only one override shader at a time can be used.
String shaderOverride = null; // "show_uvs","show_normals","show_instance_id","show_primitive_id","quick_gray","wireframe","ambient_occlusion"
if (shaderOverride.equals("ambient_occlusion")) {
float maxDist = 200f;
this.sunflow.parameter("maxdist", maxDist);
this.sunflow.shader("cmdline_override", shaderOverride);
this.sunflow.parameter("override.shader", "cmdline_override");
shaderOverride != null
EnkoNyito
Posted by VeroniQ at Jun 5, 2019, 2:38:18 PM
Nice renderings!
Posted by enkonyito at Jun 5, 2019, 6:36:46 PM
Nice renderings!
Thank you VeroniQ!
I take the opportunity to propose a small survey.
Among the new rendering options, which ones do you find most interesting?
A: show_uvs
B: show_normals
C: show_instance_id
D: show_primitive_id
E: quick_gray
F: wireframe
G: ambient_occlusion (X)
EnkoNyito
Posted by VeroniQ at Jun 5, 2019, 7:42:34 PM
I like E: Quick Grey but the colored ones (especially C and D) are fun!
Posted by ndorigatti at Jun 5, 2019, 9:42:35 PM
quick gray, wireframe and ambient occlusion (E F G)
Posted by enkonyito at Jul 1, 2019, 5:45:02 AM
The additional Sunflow options plug-in will be available with the new version of the photo-video plug-in.
Enko
EnkoNyito
Posted by williamcm at Aug 5, 2019, 3:33:03 AM
Hello hello community
how to install SunFlow
I would like to improve my rendering and how to use it? i have already downloaded but there is no executable file
Thank you william from Cameroon
Hello bonjour la communaute
comment installer SunFlow
je voudrais ameliore mes rendue et comment l utiliser? j ai telecharger deja mais il ya pas de fichier executable
Merci william depuis le cameroun
Posted by enkonyito at Aug 5, 2019, 7:20:22 PM
Hi William!
You can download the precompiled version Sunflow-v0.07.2 and run the sunflow.jar file directly or sunflow.bat after editing.
You can also download the latest version Sunflow-v0.07.3 and follow the build instructions of the README file.
Enko Nyito
EnkoNyito
Posted by Ceciliabr at Aug 8, 2019, 2:02:10 AM
@ enkonyito
Maybe this is not the right thread to discuss this, but I'm somewhat puzzled by the way Sunflow handles shininess.
It's like shininess is either on or off, with nothing in between.
I have done several tests on this, and I'm really wondering if the shininess slider has any function at all.
Is this just a result of the limitations imposed by SH3D, or is this a real Sunflow limitation?
Posted by enkonyito at Aug 9, 2019, 4:08:54 AM
@Ceciliabr
In the Modify furniture panel, Matt=0 and Shiny=0.5.
In the Furniture materials panel, Matt=0 and Shiny=1. The Java 3D preview lets you see the difference in shininess.
When rendering, Sunflow applies a shader to the material that "changes" the shininess. (see pages 14 to 23 of Sunflow Wiki PDF)
As Puybaret had told me : "There's no limitation".
Sunflow's standard configuration in Sweet Home 3D is based on several tests performed in 2010 (Test 1, Test 2).
Enko
EnkoNyito
Posted by enkonyito at Aug 23, 2019, 4:07:57 AM
* Option:
-bucket X Y
Changes the default bucket size to n pixels and the default order (BucketRenderer, MultipassRenderer).
Sunflow default value: bucketSize = 32, bucketOrder = hilbert.
SH3D default value: bucketSize = 64, bucketOrder = spiral.
int bucketSize = 16; // min = 16, max = 512
this.sunflow.parameter("bucket.size", bucketSize);
String bucketOrder = "spiral"; // hilbert, spiral, column, row, diagonal or random can be reversed
this.sunflow.parameter("bucket.order", bucketOrder);
EnkoNyito
Posted by enkonyito at May 27, 2021, 5:34:43 AM
These options will no longer be managed in the next version of the photo-video rendering plug-in.
EnkoNyito
