Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Additional Sunflow options (tests) |
| Print at Jul 21, 2026, 9:32:59 PM |
| Posted by enkonyito at Jun 3, 2019, 2:18:30 AM |
Additional Sunflow options (tests) Sunflow has command line options to control the rendering result without the GUI. The goal here is to test their actions in Sweet Home 3D. * Option: -threads X Allows you to force the number of threads used for rendering (BucketRenderer, MultipassRenderer). Default value: number of available processors. SH3D implementation: int threads = X; this.sunflow.parameter("threads", threads); this.sunflow.options(SunflowAPI.DEFAULT_OPTIONS); No major differences in rendering time if the number of virtual threads is greater than the number of actual threads available. * Options: -lopri -hipri Allows you to set the priority of the threads. Default value: lowPriority = true. SH3D implementation: boolean lowPriority = true; this.sunflow.parameter("threads.lowPriority", !lowPriority); this.sunflow.options(SunflowAPI.DEFAULT_OPTIONS); No major differences in rendering time. ---------------------------------------- EnkoNyito |
| Posted by enkonyito at Jun 4, 2019, 6:32:09 AM |
Re: Additional Sunflow options (tests) * Option: -showaa Display sampling levels per pixel for bucket renderer. Default value: showAA = false. SH3D implementation: boolean showAA = false; this.sunflow.parameter("aa.display", !showAA); this.sunflow.options(SunflowAPI.DEFAULT_OPTIONS); showAA = true showAA = false ---------------------------------------- EnkoNyito |
| Posted by enkonyito at Jun 5, 2019, 2:01:32 AM |
Re: Additional Sunflow options (tests) * Options: -quick_uvs : Renders the UVs of objects. -quick_normals : Renders the normals of objects. -quick_id : Renders using a unique color for each instance. -quick_prims : Renders using a unique color for each primitive. -quick_gray : Renders all the objects in the scene gray diffuse, overriding all shaders. -quick_wire : Renders objects as wireframe. -quick_ambocc X : Renders a scene in ambient occlusion mode with a certain distance (X). Only one override shader at a time can be used. SH3D implementation: String shaderOverride = null; // "show_uvs","show_normals","show_instance_id","show_primitive_id","quick_gray","wireframe","ambient_occlusion" if (shaderOverride.equals("ambient_occlusion")) { float maxDist = 200f; this.sunflow.parameter("maxdist", maxDist); } this.sunflow.shader("cmdline_override", shaderOverride); this.sunflow.parameter("override.shader", "cmdline_override"); this.sunflow.options(SunflowAPI.DEFAULT_OPTIONS); shaderOverride != null ---------------------------------------- EnkoNyito |
| Posted by VeroniQ at Jun 5, 2019, 2:38:18 PM |
Re: Additional Sunflow options (tests) Nice renderings! |
| Posted by enkonyito at Jun 5, 2019, 6:36:46 PM |
Re: Additional Sunflow options (tests) Nice renderings! Thank you VeroniQ! I take the opportunity to propose a small survey. Among the new rendering options, which ones do you find most interesting? A: show_uvs B: show_normals C: show_instance_id D: show_primitive_id E: quick_gray F: wireframe G: ambient_occlusion (X) ---------------------------------------- EnkoNyito |
| Posted by VeroniQ at Jun 5, 2019, 7:42:34 PM |
Re: Additional Sunflow options (tests) I like E: Quick Grey but the colored ones (especially C and D) are fun! |
| Posted by ndorigatti at Jun 5, 2019, 9:42:35 PM |
Re: Additional Sunflow options (tests) quick gray, wireframe and ambient occlusion (E F G) |
| Posted by enkonyito at Jul 1, 2019, 5:45:02 AM |
Re: Additional Sunflow options (tests) The additional Sunflow options plug-in will be available with the new version of the photo-video plug-in. Enko ---------------------------------------- EnkoNyito |
| Posted by williamcm at Aug 5, 2019, 3:33:03 AM |
Re: Additional Sunflow options (tests) Hello hello community how to install SunFlow I would like to improve my rendering and how to use it? i have already downloaded but there is no executable file Thank you william from Cameroon --------------------------------------------------------------- Hello bonjour la communaute comment installer SunFlow je voudrais ameliore mes rendue et comment l utiliser? j ai telecharger deja mais il ya pas de fichier executable Merci william depuis le cameroun |
| Posted by enkonyito at Aug 5, 2019, 7:20:22 PM |
Re: Additional Sunflow options (tests) Hello hello community how to install SunFlow I would like to improve my rendering and how to use it? i have already downloaded but there is no executable file Thank you william from Cameroon Hi William! You can download the precompiled version Sunflow-v0.07.2 and run the sunflow.jar file directly or sunflow.bat after editing. You can also download the latest version Sunflow-v0.07.3 and follow the build instructions of the README file. Enko Nyito ---------------------------------------- EnkoNyito |
Current timezone is GMT Jul 21, 2026, 9:32:59 PM |
