Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Photo-rendering failed |
| Print at Sep 20, 2026, 2:43:22 AM |
| Posted by decasicko at Mar 5, 2019, 12:50:43 PM |
Re: Photo-rendering failed After some PM with Hans, and checking Installing/Uninstalling some times Java and Sweethome3d, we determine, the problem is my computer. I made a fresh install in a laptop and works fine. (Even modifying .ini file to adjust max memory), but my computer (I7 with W10 /16GB RAM/4GB graphic card) doesn't change, offering me maximum 0.4GB. so maybe some software installed in my computer makes SH3H having incompatibility. I will continue trying options in my computer, and until i find a solution, i will edit with my computer, and i will render with the laptop (Less powerful) |
| Posted by UbuntuBirdy at Mar 5, 2019, 1:04:38 PM |
Re: Photo-rendering failed You're sure you have installed 64bit JAVA? ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by hansmex at Mar 5, 2019, 1:47:05 PM |
Re: Photo-rendering failed The problem with decasicko is/was that he tried to render a 100MB file in 0.5 MB memory. He is now trying to increase memory allowance on his PC. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by decasicko at Mar 5, 2019, 2:09:31 PM |
Re: Photo-rendering failed Bu my computer doesn't let me more than 0.4Gb, although i have 16GB RAM. I tested in other two computers and works fine, and memory allowance is good figures. Something in my computer is not working well. So, because is my problem, and not a program problem, i don't want to disturb. If i reach a solution i will tell you in case somebody else share my problem. |
| Posted by Puybaret at Mar 5, 2019, 5:00:41 PM |
Re: Photo-rendering failed Does the About dialog box show 32bit or 64bit? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by decasicko at Mar 6, 2019, 10:48:16 AM |
Re: Photo-rendering failed Hello all. SOLVED. Finally using this video (https://www.youtube.com/watch?v=R3Hj83J0ekk), and Changing the value in the first step (I modify it with -XMX8g not delete) and now i start SH3D and i see: Java version 1.8.0_202 - 64 bit - 0.1 / 7.1 GB So finally it's working. thanks a lot to all of us hwo helped me here or with Private Message. so the problem was, my system was blocking any change of memory in JAVA restricting to 512MB. |
Current timezone is GMT Sep 20, 2026, 2:43:22 AM |
