Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: What happened to the floor? |
| Print at Sep 20, 2026, 2:01:54 AM |
| Posted by ottertooth at Feb 9, 2019, 1:14:36 AM |
Re: What happened to the floor? Ok, we now have found your problem. And HERE is your solution. Thank you. Thank you. Result: It does not want to cover a small section over the stairs, but this might be good enough. Do you know how to get the floor to cover that section? |
| Posted by UbuntuBirdy at Feb 9, 2019, 11:03:09 AM |
Re: What happened to the floor? This area is not covered because of the staircaseCutOutShape defined in the model of your stairs. The easy way to fix this would be to add a box where you wish to cover the stairs (you have to paste it at the first level). The perfectionist way is to edit the staircaseCutOutShape in the home.xml in your sh3d file. ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
Current timezone is GMT Sep 20, 2026, 2:01:54 AM |
