Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: What happened to the floor? |
| Print at Sep 20, 2026, 2:15:47 AM |
| Posted by ottertooth at Feb 5, 2019, 8:09:28 PM |
What happened to the floor? House with 4 levels (incl basement). I have drawn the upper apartment (the 3rd floor) with all the walls and features, including the stairs that go down to the 2nd floor. I created a level below the upper apartment. The stairs end up there and are viewable in the 3D pane. So far so good. But when I drew some walls on the 2nd floor, in the stairs landing area, the floor/ceiling between the 3rd floor and the 2nd floor disappeared. How do you put the floor back in? Adjusting the height of the walls doesn't solve the problem. |
| Posted by hansmex at Feb 6, 2019, 11:57:34 AM |
Re: What happened to the floor? Impossible to help you if you don't share your design... H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by ottertooth at Feb 7, 2019, 8:28:27 AM |
Re: What happened to the floor? Why? Most threads here don't have pictures. What do you need exactly? The file? |
| Posted by Puybaret at Feb 7, 2019, 11:16:50 AM |
Re: What happened to the floor? An image is often more meaningful than some words. Anyway... I think that selecting the 3D view > Display all levels menu item might help in your case. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by ottertooth at Feb 8, 2019, 9:51:22 PM |
Re: What happened to the floor? In '3D View' in Menu it already has the "Display all levels" checked. There should be a floor, so I shouldn't be able to see the bottom of the stairs. I shouldn't be able to see the doorway, because it is below the floor. I looked in one of the demos. You have a 3-storey house demo. There are floors in it. You can't see through them. But when I started adding walls to the 2nd floor in mine, the floor/ceiling disappeared. |
| Posted by UbuntuBirdy at Feb 8, 2019, 10:34:48 PM |
Re: What happened to the floor? And have you added floors too? ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by ottertooth at Feb 9, 2019, 12:29:02 AM |
Re: What happened to the floor? No, I don't know how. That's my question. What else do I need to say, I've even posted a picture that shows the problem... Floors appeared automatically as I was drawing the top apartment. When I started drawing the 2nd storey apartment, the floor that was already there, disappeared. I don't see any option for adding floors and am not seeing anything about creating floors in 'help'. I just see how to adjust floor thickness. But I can't do that when there's no floor to begin with. |
| Posted by VeroniQ at Feb 9, 2019, 12:34:04 AM |
Re: What happened to the floor? This thread will give you some advice to share your picture. About your floor, are you sure you create a room before? |
| Posted by ottertooth at Feb 9, 2019, 12:44:40 AM |
Re: What happened to the floor? This thread will give you some advice to share your picture. About your floor, are you sure you create a room before? Thank you, but that is exactly what I did to post the image. For some reason the thumbnail indicates a dead link. But it isn't dead. You have to click 'copy image' and paste it into a new tab. No, I didn't create any rooms. I simply drew the walls and added 'furniture' afterwards. |
| Posted by UbuntuBirdy at Feb 9, 2019, 12:48:44 AM |
Re: What happened to the floor? Ok, we now have found your problem. And HERE is your solution. ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
Current timezone is GMT Sep 20, 2026, 2:15:47 AM |
