Print at Sep 20, 2026, 12:25:36 AM
Posted by ottertooth at Feb 5, 2019, 8:09:28 PM
What happened to the floor?
House with 4 levels (incl basement). I have drawn the upper apartment (the 3rd floor) with all the walls and features, including the stairs that go down to the 2nd floor. I created a level below the upper apartment. The stairs end up there and are viewable in the 3D pane. So far so good. But when I drew some walls on the 2nd floor, in the stairs landing area, the floor/ceiling between the 3rd floor and the 2nd floor disappeared. How do you put the floor back in? Adjusting the height of the walls doesn't solve the problem.
Posted by hansmex at Feb 6, 2019, 11:57:34 AM
Re: What happened to the floor?
Impossible to help you if you don't share your design...
Posted by ottertooth at Feb 7, 2019, 8:28:27 AM
Why? Most threads here don't have pictures. What do you need exactly? The file?
Posted by Puybaret at Feb 7, 2019, 11:16:50 AM
An image is often more meaningful than some words.
Anyway... I think that selecting the 3D view > Display all levels menu item might help in your case.
Posted by ottertooth at Feb 8, 2019, 9:51:22 PM
In '3D View' in Menu it already has the "Display all levels" checked.
There should be a floor, so I shouldn't be able to see the bottom of the stairs. I shouldn't be able to see the doorway, because it is below the floor. I looked in one of the demos. You have a 3-storey house demo. There are floors in it. You can't see through them. But when I started adding walls to the 2nd floor in mine, the floor/ceiling disappeared.
Posted by UbuntuBirdy at Feb 8, 2019, 10:34:48 PM
And have you added floors too?
Pascal
Posted by ottertooth at Feb 9, 2019, 12:29:02 AM
No, I don't know how. That's my question. What else do I need to say, I've even posted a picture that shows the problem... Floors appeared automatically as I was drawing the top apartment. When I started drawing the 2nd storey apartment, the floor that was already there, disappeared. I don't see any option for adding floors and am not seeing anything about creating floors in 'help'. I just see how to adjust floor thickness. But I can't do that when there's no floor to begin with.
Posted by VeroniQ at Feb 9, 2019, 12:34:04 AM
This thread will give you some advice to share your picture. About your floor, are you sure you create a room before?
Posted by ottertooth at Feb 9, 2019, 12:44:40 AM
Thank you, but that is exactly what I did to post the image. For some reason the thumbnail indicates a dead link. But it isn't dead. You have to click 'copy image' and paste it into a new tab.
No, I didn't create any rooms. I simply drew the walls and added 'furniture' afterwards.
Posted by UbuntuBirdy at Feb 9, 2019, 12:48:44 AM
Ok, we now have found your problem. And HERE is your solution.
Pascal
