Print at Sep 19, 2026, 11:58:03 PM View all posts in this thread on one page
Posted by SporSeba97 at Dec 29, 2018, 3:21:42 PM
Problem with OpenGL
Hello everyone,
after some time I have installed Sweet Home 3D again.
Now I get when I start the program the error that I need to update the driver of the graficcard.
My problem is now, that I have updated the driver and I get the error also.
This is my system:
Windows 10 Education 64-bit
CPU: Intel i7-4790K
RAM: 16GB
GPU: Nvidia GTX-970 Driver Verison: 417.35
JRE and JDK Version: 1.8.0_191
I have also tryed older versions of Sweet Home 3D, there I got the same error.
Moreover I have tryed the executable jar version. If I run this from the commandline I get the following error:
javax.media.j3d.IllegalRenderingStateException: Java 3D ERROR : OpenGL 1.2 or better is required (GL_VERSION=1.1) at javax.media.j3d.JoglPipeline.setupCanvasProperties(JoglPipeline.java:8090) at javax.media.j3d.JoglPipeline.createNewContext(JoglPipeline.java:6439) at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:4612) at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:2386) at javax.media.j3d.Renderer.doWork(Renderer.java:881) at javax.media.j3d.J3dThread.run(J3dThread.java:271) Error in Java 3D : 3 Renderer: Error creating Canvas3D graphics context
I have also reinstalled java (jre and jdk), the driver of the graficcard and all nvidia software, which I have found on my system. I don't know which more software I need to reinstall.
I have no problems with minecraft which is also running with java and OpenGL.
Does anyone have an idea, who I can fix the probleme without an windows reinstallation?
Posted by Puybaret at Jan 8, 2019, 3:00:46 PM
Re: Problem with OpenGL
Did you try both 32 bit and 64 bit versions, selecting either Architecture options in the installation folder screen of Sweet Home 3D installer?
Posted by pfranzini at Jan 20, 2019, 10:24:18 AM
I have the same problem too
This is my system:
Windows 10 Home 64-bit
CPU: Intel i7-6700K
RAM: 32GB
GPU: Nvidia GeForce 1080 Driver Version: 417.17
java version "1.8.0_201"
Java(TM) SE Runtime Environment (build 1.8.0_201-b09)
Java HotSpot(TM) 64-Bit Server VM (build 25.201-b09, mixed mode)
try with 32/64 bit:
in task manager Java Platform SE Binary appears and disappears in a moment
tryed the executable jar version:
the same problem as SporSeba97
some idea?
Posted by pfranzini at Jan 26, 2019, 1:42:34 PM
smile   Re: Problem with OpenGL
Update:
with this CMD line work!
C:\Program Files (x86)\Java\jre1.8.0_201\bin\java "-client" "-d32" "-Dj3d.rend=d3d" "-Dcom.eteks.sweethome3d.j3d.version=1.5.2" -jar C:\Temp\SweetHome3D-6.1.jar"
Posted by pfranzini at Jan 25, 2021, 11:42:02 AM
UPDATE 2021.01:
J'ai créé le fichier SweetHome3D.l4j.ini
comme décrit ici : http://www.sweethome3d.com/fr/faq.jsp#errorIn3DRenderingSystem
et l'a ensuite copié dans:
C:\Program Files (x86)\Sweet Home 3D
en :
C:\Program Files (x86)\Sweet Home 3D\
J'ai renommé le répertoire jre8 de SH3D en _jre8
J'ai créé un nouveau répertoire jre8
J'ai copié les répertoires bin et lib du répertoire
C:\Program Files (x86)\Java\jre1.8.0_271
dans
C:\Program Files (x86)\Sweet Home 3D\jre8
fonctionne maintenant
