Print at Sep 20, 2026, 4:47:10 AM
Posted by Larz2 at Dec 3, 2018, 12:19:57 PM
Top category library
Hello,
I have built a new furniture library with a new name. How can I make this library be current / top category, when opening SH3D?
As it is now, the current category is "All" (Preference setting: Furniture catalog view: Searchable list).
Thanks in advance!
(SH3D version 6.0 on Windows 7)
Posted by Puybaret at Dec 4, 2018, 2:22:54 AM
Re: Top category library
This can’t be changed.
Posted by Larz2 at Dec 4, 2018, 12:38:19 PM
OK thanks Puybaret.
Is it possible to delete or remove libraries, which will not be used, from the category list?
Posted by dorin at Dec 5, 2018, 8:03:46 PM
The "category" are parts in a "library".
In furniture window You see only the category from all installed libraries.
You could do one of this:
-remove the entire library from home folder (including those with pieces You need)
-edit the PluginFurnitureCatalog.properties files in every library.(e.g. I have 50+)
Anyway almost everything is possible if You relay want (not all are easy).
Posted by Larz2 at Dec 8, 2018, 11:08:20 AM
Thank you for your tip Dorin, I will try to edit the list of libraies.
Best regards,
Lars
