Print at Sep 21, 2026, 1:31:20 AM
Posted by Mike53 at Nov 16, 2018, 11:49:44 PM
Re: massive color-difference
Not so sure this is a new topic, i seem to recall questioning it a couple of years ago, i have found that using textures is far more accurate than colors, here are 2 images, 1 a screenshot the other a render.
and this is a Q4 render
not only does the red change to pink but it also shows how different objects color differently, the I beams are rooms and the roller support brackets are box's, both have the same color applied to them.
Posted by hal9000 at Dec 6, 2019, 9:05:17 PM
Well, more than 1 year after the last post, but... Has somebody tried to render one of these projects with YafaRay to see if the color difference between a pure color and a texture of the same color is still there?
Posted by UbuntuBirdy at Dec 7, 2019, 12:26:30 PM
Interesting idea. Yes, I have, but unfortunately I have changed all my projects from colored to textured objects.
But I will this give a try.
Pascal
Posted by enkonyito at Dec 13, 2019, 3:28:20 AM
@UbuntuBirdy
This picture shows what's wrong in my opinion:
- The left cube has a texture which is only colored as #520015
- The right cube has the color #520015 directly
In my opinion both cubes should look the same, we should see exactly the same color. But only the textured cube shows the color #520015 as it should be.
I think the difference comes from the way Java 3D processes colors or textures.
Example of rendering in quality 1.
Enko
EnkoNyito
Posted by Mike53 at Feb 21, 2021, 12:24:25 PM
Not sure if this issue has been attended to but i am still getting the same issue
Roof with colour:-
Roof with texture:-
Posted by hansmex at Feb 21, 2021, 12:40:35 PM
This is a known "problem". Using an even-coloured texture is the solution, as you already found out.
Posted by Mike53 at Feb 21, 2021, 2:16:11 PM
Just because it is something that is a "KNOWN PROBLEM" shouldn't mean we have to continue with "work arounds" rather than sorting the issues.
As a maintenance engineer i quite often use "work arounds" when needed to get a machine running, but, these are temporary, I return as soon as possible to properly make repair.
Posted by reddy.shyam at Feb 26, 2021, 7:47:43 AM
While we are at it, is my issue same as well? All my bright colors become pale when I generate an image. Please see attached.
Any setting I need to change while generating image?
Cannot attach any image host files for some reason. Tried imgur and prnt.sc`
Posted by kutlu9 at Mar 14, 2021, 9:20:22 AM
I'm having same problem as reddy.shyam. I was using the programm without any problems, suddenly my images become over exposed. Uninstall/reinstall didn't solved it.
I noticed sky texture or color doesn't render (rendering with only pure white color) making final image over exposed.
Posted by c0d3z3r0 at Dec 27, 2024, 9:40:17 PM
The problem seems to be that Java3D expects Linear RGB as input color space:https://forum.jogamp.org/sRGB-and-gamma-correction-in-Java3d-td4038946.html
I've tested this by manually setting the RGB value of a wall to a gamma-corrected value ( lin=255*(val/255, 2.2) ), which makes yafaray and sunflow output the correct color.
There are two options: 1) feed in a generated texture or 2) convert the colors to linear RGB
