Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Where to install .eteks |
| Print at Sep 25, 2026, 2:19:30 PM | View all posts in this thread on one page |
| Posted by carltonwb at Sep 5, 2018, 1:04:22 AM |
Where to install .eteks Using Mint 19 I installed Sweethome3d in the /opt directory. Where do I install the .eteks folder in order to use the plugins. Also if I installed this through the software channel it creates a snap file, where would I install the .eteks folder in that case. Thanks carltonb |
| Posted by Puybaret at Sep 6, 2018, 11:30:33 AM |
Re: Where to install .eteks Run once Sweet Home 3D and modify something in its preferences to let the software create the .eteks/sweethome3d folder in your home directory. Then you can create a subfolder named plugins in .eteks/sweethome3d. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by carltonwb at Sep 6, 2018, 9:35:38 PM |
Re: Where to install .eteks Thanks worked exactly as you stated. |
Current timezone is GMT Sep 25, 2026, 2:19:30 PM |
