Print at Sep 25, 2026, 3:19:19 PM
Posted by carltonwb at Sep 5, 2018, 1:04:22 AM
Where to install .eteks
Using Mint 19
I installed Sweethome3d in the /opt directory.
Where do I install the .eteks folder in order to use the plugins.
Also if I installed this through the software channel it creates a snap file, where would I install the .eteks folder in that case.
Thanks
carltonb
Posted by Puybaret at Sep 6, 2018, 11:30:33 AM
Re: Where to install .eteks
Run once Sweet Home 3D and modify something in its preferences to let the software create the .eteks/sweethome3d folder in your home directory. Then you can create a subfolder named plugins in .eteks/sweethome3d.
Posted by carltonwb at Sep 6, 2018, 9:35:38 PM
Thanks worked exactly as you stated.
