Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: RULES FOR DEFINING 3D STRUCTURE |
| Print at Sep 13, 2026, 11:23:55 AM | |
| Posted by ajay94 at Aug 27, 2018, 4:49:43 PM |
RULES FOR DEFINING 3D STRUCTURE Hi all , Thanks for making sweet home 3D , i have a query as in can the code be modified enough to create rules for particular structure eg , can the rules for bedroom size , bathroom size and kitchen size be made if the total area is input by the user ? Thank you Ajay sahu |
| Posted by Puybaret at Aug 27, 2018, 7:26:39 PM |
Re: RULES FOR DEFINING 3D STRUCTURE What kind of rules do you have in mind? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by ajay94 at Aug 28, 2018, 6:29:46 AM |
Re: RULES FOR DEFINING 3D STRUCTURE Standard rules like bedroom area will be thrice of the kitchen area or bathroom area is 1/2 of the kitchen area .certain rules for standard area accoring to the BHK eg 1 BHK , 2BHK Ajay Sahu |
| Posted by VeroniQ at Aug 29, 2018, 2:55:25 PM |
Re: RULES FOR DEFINING 3D STRUCTURE I would say that it depends mostly on national regulations and habits, no ?... |
| Posted by ajay94 at Aug 31, 2018, 11:36:03 AM |
Re: RULES FOR DEFINING 3D STRUCTURE yes , but me question was , can the code be modified to create rules , is it possible ? |
| Posted by Puybaret at Aug 31, 2018, 2:59:25 PM |
Re: RULES FOR DEFINING 3D STRUCTURE As with any program, you can program all the controls you want. But the good question is when and how should be displayed the controls you want to add. If you display a popup as soon as your conditions are not verified, this may interrupt user's input. If you want to add a menu item that will check your conditions, you might not be able to force the user to modify his design. Maybe you could try to program a plug-in for this? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 13, 2026, 11:23:55 AM |
