Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Wall capy and paste |
| Print at Oct 1, 2026, 8:41:00 PM | |
| Posted by esse2003 at Jul 14, 2018, 8:39:29 PM |
Wall capy and paste Hi all. Is possible to make a copy and paste of walls already built in another project? I need them with a certain angle, that’s the problem. Is that possible? I don’t want to import as an obj because then i cannot edit anymore. Thanks again! |
| Posted by Puybaret at Jul 14, 2018, 9:33:27 PM |
Re: Wall capy and paste You can select the walls you want to copy, choose Edit > Copy menu item, open the other project, click in its plan and choose Edit > Paste menu item. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by esse2003 at Jul 15, 2018, 12:10:34 AM |
Re: Wall capy and paste Yes, that’s correct but then i cannot give to the walls an angle? Right? |
| Posted by Puybaret at Jul 15, 2018, 1:54:22 PM |
Re: Wall capy and paste Maybe you could try AdvancedEditing plugin? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by esse2003 at Jul 15, 2018, 3:50:06 PM |
Re: Wall capy and paste I tried but you cannot do nothing with walls. There is not a function ti rotate walls unfortunately. Thanks anyway.. |
| Posted by Puybaret at Jul 16, 2018, 11:30:36 AM |
Re: Wall capy and paste I just tried and you can rotate walls with the plugin. Please try again. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 1, 2026, 8:41:00 PM |
