Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: SH3D on Windows 10 on ARM works using DirectX |
| Print at Sep 29, 2026, 6:02:17 AM | |
| Posted by arm64appcompatguy at Jun 8, 2018, 9:17:01 PM |
SH3D on Windows 10 on ARM works using DirectX Hi, I'm one of the Microsoft employees tasked with getting various apps to work well on Windows 10 on ARM. Sweet Home 3D is on my list. One of the unfortunate limitations of the current ARM64 Windows devices is that they have no OpenGL support in their drivers. This means that the amazing Windows installer provided by Sweet Home 3D works fine, but the application tends to either crash on start or leave the rendering area blank. Because of this I added an app compat shim to block the current major revision of the installer from running. Not satisfied with this, I went digging on the forum and found this wonderful post: http://www.sweethome3d.com/support/forum/viewthread_thread,6818_offset,7 The instructions there for using the JAR version of the program with -Dj3d.rend=d3d work beautifully, and Sweet Home 3D actually performs quite well under our emulation. I hope this helps someone out. Sweet Home 3D is really a neat product. Thanks! |
| Posted by Puybaret at Jun 9, 2018, 12:37:08 AM |
Re: SH3D on Windows 10 on ARM works using DirectX Thanks for your tests The DirectX version of Java 3D requires to run Sweet Home 3D in 32 bit. Isn't it a problem under ARM64? Did you run Sweet Home 3D with its JAR Executable version or from the installer running with /j3d.version=1.5.2 /os.arch=x86 flags and a SweetHome3D.l4j.ini file containing DirectX properties placed in Sweet Home 3D installation folder? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by arm64appcompatguy at Jun 11, 2018, 10:43:04 PM |
Re: SH3D on Windows 10 on ARM works using DirectX Glad I can help :) ARM64 Windows has 32-bit Intel/AMD CPU emulation software. This allows it to run normal 32-bit Java programs quite well. Sadly, in all of my research and experimentation I did not see those installer flags and I'm not sure what to put in the INI. I'll work on that since the EXE installer is quite preferable to what I got working! My steps:
| Posted by arm64appcompatguy at Jun 12, 2018, 3:11:38 AM |
Re: SH3D on Windows 10 on ARM works using DirectX I was able to use the normal Windows installer just like you suggested:
Would you be OK with the OS compatibility layer automatically adding the needed installer arguments and INI entry on ARM64? This wouldn't be applied once the version exceeds, say, 5.7. I still haven't figured out how to get High DPI support working right using the INI file. The INI entries suggested in the FAQ have no effect and don't seem to track changes in the OS' DPI settings. |
| Posted by Puybaret at Jul 6, 2018, 3:45:33 PM |
Re: SH3D on Windows 10 on ARM works using DirectX Actually, I think that the list of properties in the SweetHome3D.l4j.ini should be a little longer: -Dj3d.rend=d3dWould you be OK with the OS compatibility layer automatically adding the needed installer arguments and INI entry on ARM64? As it's possible to test ARM64 architecture in Inno Setup, it should be even possible to change the installer in such a way that when running under ARM64, it will install by default Sweet Home 3D in 32 bit with Java 3D 1.5.2 and j3d.rend property set to d3d. I still haven't figured out how to get High DPI support working right using the INI file. The INI entries suggested in the FAQ have no effect Do you mean you tried to add the following properties:-Dcom.eteks.sweethome3d.resolutionScale=2.5 ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by arm64appcompatguy at Jul 19, 2018, 10:42:34 PM |
Re: SH3D on Windows 10 on ARM works using DirectX Hi again! While -Dj3d.rend=d3d gets it minimally working in the ARM64 case, I defer to your judgement. Getting the installer to automatically set it up right would be magnificent. The less the OS does special, the better! If you go this route, please post here when the new installer is up. :) As for high-DPI, yes, I believe that was the combination of settings I tried...but I'll try again. It's been a while. (This is plain high-DPI trouble, not ARM64-specific, so I'm not particularly worried about it myself.) |
| Posted by arm64appcompatguy at Jul 19, 2018, 11:43:50 PM |
Re: SH3D on Windows 10 on ARM works using DirectX Confirmed: those settings don't fix high-dpi issues in SH3d on ARM64. |
| Posted by arm64appcompatguy at Jul 20, 2018, 1:37:42 AM |
Re: SH3D on Windows 10 on ARM works using DirectX I hope you'll excuse that last response; my testing environment was not sane and the standard entries work magnificently. More in a moment. |
| Posted by arm64appcompatguy at Jul 20, 2018, 1:49:52 AM |
Re: SH3D on Windows 10 on ARM works using DirectX So, until the installer is fixed, here's how to get Sweet Home 3D working on Windows 10 on ARM:
Hopefully that gets you rolling! |
| Posted by Puybaret at Sep 23, 2018, 4:13:26 PM |
Re: SH3D on Windows 10 on ARM works using DirectX I integrated your proposal in the version 6.0 Beta 12 found here. Could you test it please? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by treehousenorris2 at Nov 21, 2024, 7:32:37 PM |
Re: SH3D on Windows 10 on ARM works using DirectX I have a Surface Pro with Windows 11 Home that already has DirectX 12, using my fork of 7.4 with a 32 bit install. The 3D rendering pane contents looked correct, but sometimes the dialog boxes (to edit a wall's settings for example) would have areas of grayed pixels or the whole dialog was black. And eventually would show a popup that "must exit now because of a fatal error in 3D rendering system. Do you want to save all modified homes?". I tested the last solution by arm64appcompatguy with the reinstall and saw that it applied because the metal-colored menus were present. However, I could still trigger the fatal error message by opening a(nother) new (empty) home. A confirm box just before that said "Neither the Hardware and Software renderers..." |
Current timezone is GMT Sep 29, 2026, 6:02:17 AM |
