Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: On Sweet Home 3D version 5.7 I do not find many furniture i had in 5.5.2. |
| Print at Sep 27, 2026, 1:59:52 AM | |
| Posted by corradoventu at May 18, 2018, 10:05:21 PM |
On Sweet Home 3D version 5.7 I do not find many furniture i had in 5.5.2.On Sweet Home 3D version 5.7 I do not find many furniture i had in 5.5.2. How can I recover them? do I have to import a library? which one? Thanks. Corrado. |
| Posted by Puybaret at May 19, 2018, 1:48:56 AM |
Re: On Sweet Home 3D version 5.7 I do not find many furniture i had in 5.5.2. If you didn’t change computer or reinstall everything on your computer, upgrading to a new version of Sweet Home 3D shouldn’t have changed the content of your catalog. Anyway, you may also download additional libraries here. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by corradoventu at May 19, 2018, 7:23:30 AM |
Re: On Sweet Home 3D version 5.7 I do not find many furniture i had in 5.5.2. I installed new Ubuntu 18.10 Cosmic in a different partition of my computer so I have not updated but reinstalled. From the pages You suggest I have no idea of the content of each library so i risk to import a lot of things i don't need. Can I instead export the libraries i still have on the old version to import them in the new one? Thanks Note: Sweet Home 3D version 5.7 works fine on Ubuntu 18.10 Cosmic. Thanks again! |
| Posted by Puybaret at May 19, 2018, 4:46:54 PM |
Re: On Sweet Home 3D version 5.7 I do not find many furniture i had in 5.5.2. See this post to see which folder to copy to get the same catalogs. But keep in mind that a SH3D file contains all the 3D models it needs. Hum... and please, no double post! ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by corradoventu at May 19, 2018, 5:31:45 PM |
Re: On Sweet Home 3D version 5.7 I do not find many furniture i had in 5.5.2. 1) SH3D file contains all the 3D models it needs. in old projects created with 5.5.2 i see all 3D models I need more models for the NEW projects created by 5.7 2) in Ubuntu 17.10 where I have 5.5.2 .eteks/sweethome3d seems empty 3) it was not a double post, the other one is just a note about new version. |
| Posted by Puybaret at May 20, 2018, 7:57:16 PM |
Re: On Sweet Home 3D version 5.7 I do not find many furniture i had in 5.5.2. As nobody can guess what 3D models you need, you'll have to take your time to explore and install the models available at free models page or elsewhere. Downloading libraries will just speed up the process to get all free models. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by corradoventu at May 24, 2018, 10:57:34 AM |
Re: On Sweet Home 3D version 5.7 I do not find many furniture i had in 5.5.2. In an old project i used a bathroom furniture called 'small lavatory' and i'm unable to find in the libraries you cite. Furniture Library editor does not work, so the search is not easy. |
| Posted by Puybaret at May 24, 2018, 12:19:26 PM |
Re: On Sweet Home 3D version 5.7 I do not find many furniture i had in 5.5.2. Why don't you simply copy / paste this object from your old project to the new project? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by corradoventu at May 24, 2018, 10:00:50 PM |
Re: On Sweet Home 3D version 5.7 I do not find many furniture i had in 5.5.2. I found the object and copied into new project but I also discovered that import library does not work in Sweet Home 3D version 5.7 so the problem is not only in library editor. Will try to prepare doc and open a bug. |
| Posted by Puybaret at May 24, 2018, 11:17:22 PM |
Re: On Sweet Home 3D version 5.7 I do not find many furniture i had in 5.5.2. Are you sure you tried to import the SH3F file contained in the ZIP files available for download, and not the ZIP files themselves? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by corradoventu at May 25, 2018, 8:14:44 AM |
Re: On Sweet Home 3D version 5.7 I do not find many furniture i had in 5.5.2. I'm sure, the same import works fine on 5.5.2 and does not work in 5.7 and message says clearly '... library "...sh3f" was successfully imported... |
| Posted by corradoventu at May 25, 2018, 9:01:57 AM |
Re: On Sweet Home 3D version 5.7 I do not find many furniture i had in 5.5.2. imported libraries (also if .zip) are correctly inserted in .eteks/sweethome3d corrado@corrado-p8-bionic:~$ ls .eteks -AR .eteks: sweethome3d .eteks/sweethome3d: furniture languages preferences.xml textures .eteks/sweethome3d/furniture: 3DModels-Scopia-1.6.3.zip Contributions.sh3f LucaPresidente.sh3f Scopia.sh3f .eteks/sweethome3d/languages: .eteks/sweethome3d/textures: corrado@corrado-p8-bionic:~$ |
| Posted by corradoventu at May 26, 2018, 5:04:40 PM |
Re: On Sweet Home 3D version 5.7 I do not find many furniture i had in 5.5.2. For the problem about library import i opened a bug: https://bugs.launchpad.net/ubuntu/+source/sweethome3d/+bug/1773532 if you have a launchpad account please subscribe. |
| Posted by corradoventu at Jul 10, 2018, 8:53:56 AM |
Re: On Sweet Home 3D version 5.7 I do not find many furniture i had in 5.5.2. Using snap version installed in Ubuntu 18.10 from Ubuntu Software library import works fine from SH3F file contained in the ZIP files but if importing from ZIP file I have the message '.. imported' but nothing is really imported. Also Sweet Home can't open a project located on a different partition. |
Current timezone is GMT Sep 27, 2026, 1:59:52 AM |
