Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Icons missing from toolbar on Surface 4 |
| Print at Sep 22, 2026, 12:22:15 AM | |
| Posted by sdlafferty at Mar 16, 2018, 4:26:44 PM |
Icons missing from toolbar on Surface 4 I have Sweet Home 5.7 installed on two PCs; a desktop and my Surface Pro 4 laptop. Everything is fine on the Desktop, but on the Surface several of the icons (rotate, move, flip, resize and edit points) are missing. I've uninstalled and reinstalled without change. Is it somehow related to the resolution of the Surface? They were missing on first install, and still missing after using the SweetHome3D.l4j.ini workaround to set the font size and scaling. Is there something I can do to get them to show? |
| Posted by Puybaret at Mar 22, 2018, 2:14:28 AM |
Re: Icons missing from toolbar on Surface 4 These icons are not part of the base version. You should install the Advanced Editing plug-in available here to get them. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by sdlafferty at Mar 26, 2018, 3:27:30 PM |
Re: Icons missing from toolbar on Surface 4 Thank you. I must have installed that plug-in on my desktop machine a long time ago. Don't even remember doing it. Thanks. |
Current timezone is GMT Sep 22, 2026, 12:22:15 AM |
