Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: hdpi revisited on Linux |
| Print at Sep 22, 2026, 12:22:28 AM | |
| Posted by tk1138 at Mar 11, 2018, 1:26:54 PM |
hdpi revisited on Linux hello, I trying to get Sweet Home 3D to display better, larger text, in Linux running with a 4K monitor. I've downloaded the latest version, 5.7. Java is locally installed, from webupd8 ppa. java version "9.0.4" but it looks like the distribution has its own local jre8? I created this file "SweetHome3D.l4j.ini" and placed it in the expanded installed directory and in ./lib from there. the file has this single line : Dcom.eteks.sweethome3d.resolutionScale=2I thought I had this displaying nicely in an older version of Sweet Home 3D, 5.2 release. but this doesn't seem to work in 5.7? Is there something else I can do to make the text look larger in Linux? I'm use a pre-release of xubuntu Bionic 18-04. thanks |
| Posted by tk1138 at Mar 11, 2018, 1:29:28 PM |
Re: hdpi revisited on Linux typo. it was in 5.4 when I tried this last. It was a while ago, and I dont remember if I just worked around the problem and used a regular DPI monitor. |
| Posted by Puybaret at Mar 11, 2018, 3:23:12 PM |
Re: hdpi revisited on Linux The SweetHome3D.l4j.ini file is only for windows and you forgot to add an hyphen if in front of -D Java option. Under Linux, you should edit the SweetHome3D file and add all the options cited in the FAQ Texts in the furniture catalog are not displayed correctly or icons in the toolbar appear very small on my computer. How can I fix that?. If you add only the -Dcom.eteks.sweethome3d.resolutionScale=2 option, it won't work because it's possible to change font size only in Metal look and feel. There's no need to install Java since the installer provided in Download page already comes with a copy of Java 8. Anyway, I'm not sure that Sweet Home 3D is able to work under Java 9. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by tk1138 at Mar 11, 2018, 5:59:41 PM |
Re: hdpi revisited on Linux Thanks. I tried this modification - and when I start up, I get this --- I see an initial splash screen.. and it just hangs. |
| Posted by Puybaret at Mar 11, 2018, 6:24:29 PM |
Re: hdpi revisited on Linux Then try with SweetHome3D-Java3D-1_5_2 script. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by tk1138 at Mar 11, 2018, 11:15:13 PM |
Re: hdpi revisited on Linux yes, that worked, thank you. $ cat SweetHome3D-Java3D-1_5_2 |
Current timezone is GMT Sep 22, 2026, 12:22:28 AM |
