Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Import Furniture |
| Print at Aug 16, 2026, 8:11:45 AM |
| Posted by peterweaver at Mar 6, 2018, 9:09:02 PM |
Re: Import Furniture I have just figured it out. Cheers |
| Posted by CIANFRES at Apr 2, 2018, 10:35:40 PM |
Re: Import Furniture Hi, I've downloaded a model .obj but i can't import it in my sweet home 3d. I've a Mac, maybe is it a problem? I've downloaded it from a web site and in every folder there is the object and other files. How can I import correctly the object? Thank you Francesca from Italy |
| Posted by Puybaret at Apr 3, 2018, 1:23:16 AM |
Re: Import Furniture If you use the Mac App Store version, you should import 3D models in zip archives. For more information, please read the FAQ How can I import 3D models in OBJ, DAE or 3DS format with the Mac App Store version of Sweet Home 3D? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Steveworld7 at Dec 21, 2021, 3:11:44 PM |
Re: Import Furniture Colours are exported in the separated MTL file. When you import an OBJ file, you should generally keep the MTL file in the same folder (or the same ZIP file). Hi! I have a ZIP file with a list of files inside as: 3ds, dae, obj, mtl and texture folders) Importing this ZIP, the pouf inside remains white. Any suggest? Thanks |
| Posted by Puybaret at Dec 21, 2021, 6:29:05 PM |
Re: Import Furniture DAE and 3DS files contain colors, at the opposite of OBJ files which colors are described in their accompanying MTL file (and sometime not well described). I would extract the DAE file ans try to import it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Steveworld7 at Dec 27, 2021, 1:31:44 PM |
Re: Import Furniture I tried to import the .dae file only (after zipping it) but the pouf remains white ... Inside this zip file there are 3 folders called: LODs, render, textures ... should I have to import these folders somehow? |
| Posted by Jo_Alfemo at Dec 27, 2021, 6:18:40 PM |
Re: Import Furniture Hi If I want to make a texture what is the ideal size? Tks |
| Posted by dape at Mar 18, 2022, 12:05:39 PM |
Re: Import Furniture Hi Peter, do not know if this can help, but if you are looking for more free 3D furniture models (and many more download formats), try here with 3DfindIT.com (have to register and then you can download for free whatever you need). Hope it helps, take care! https://www.3dfindit.com/textsearch?lang=en_US&q=furniture |
Current timezone is GMT Aug 16, 2026, 8:11:45 AM |
