Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 5.7 |
| Print at Sep 30, 2026, 1:29:00 AM |
| Posted by Puybaret at Jan 25, 2018, 11:59:00 PM |
Sweet Home 3D 5.7 For your information, I released Sweet Home 3D 5.7 today. It's a maintenance release that fixes some bugs listed here and brings a small additional feature that allows to display a preview of images in file choosers. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Xiste at Jan 30, 2018, 11:47:37 AM |
Re: Sweet Home 3D 5.7 In the Q&A: @ With the free version under Mac OS X, , click on the application icon of Sweet Home 3D while maintaining the ctrl key pressed to display its contextual menu, choose Show Package Contents item, open the Contents folder, edit the Info.plist file by dragging its icon on TextEdit application and update the maximum memory in the text <string>-Xmx1024m</string>, writing for example <string>-Xmx2g</string> for 2 GB instead of 1024 MB. Finally, save the file and relaunch Sweet Home 3D. It no longer works, as the Info-plist file in version 5.7 is locked by default. Since there most probably no lomger exists any Mac with less than 8G memory, why not set the default memory to 6G or 8G? It will save Mac-users a lot of hassle. Xi |
| Posted by Puybaret at Jan 30, 2018, 12:21:49 PM |
Re: Sweet Home 3D 5.7 Since there most probably no lomger exists any Mac with less than 8G memory [...] I wish things could be so easy, but I'm sure that there are still many Mac OS X users running computers with less RAM than that, or even with a 32 bit processor, the main reason why this max memory value will remain at 1 GB for a few more releases. If Info.plist is protected, you may run a command like: sudo nano /Applications/Sweet\ Home\ 3D.app/Contents/Info.plist---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Xiste at Jan 30, 2018, 1:24:11 PM |
Re: Sweet Home 3D 5.7 f Info.plist is protected, you may run a command like: -sudo nano /Applications/Sweet\ Home\ 3D.app/Contents/Info.plist Result: -bash: -sudo: command not found As an experiment I opened version 5.6 (8G) on an antique Powerbook, and it runs perfectly. So it doesn't seem to matter wheter the memory is set to 1024m or 8G. Xi |
| Posted by Puybaret at Jan 30, 2018, 1:42:34 PM |
Re: Sweet Home 3D 5.7 Sorry, there was a useless hyphen in front of sudo. As an experiment I opened version 5.6 (8G) on an antique Powerbook, and it runs perfectly. So it doesn't seem to matter wheter the memory is set to 1024m or 8G. The -Xmx flag sets the max memory usable by Sweet Home 3D, not the minimum or the value at start. It will run perfectly as long as you use less than 1 GB or so, if the computer runs under a 32 bit system. If it runs under a 64 bit system with little RAM, it will probably start to swap once the RAM is full.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Darshiit at Jan 30, 2018, 4:24:26 PM |
Re: Sweet Home 3D 5.7 Thanks Puybaret :) |
| Posted by serinter at Feb 17, 2018, 8:53:59 PM |
Re: Sweet Home 3D 5.7When I updated to the new version yesterday, (5.7.) I could not save any files, and also not open any file! When i make a simple project, go to save, the window open to save, but nothing happens .. Any idea? |
| Posted by Puybaret at Feb 17, 2018, 10:45:43 PM |
Re: Sweet Home 3D 5.7 Do you use the installer version or the Java Web Start version? Under which system? What do you mean by "nothing happens": does the program seem to hang, or does an error message appear? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Ceciliabr at Feb 19, 2018, 12:02:38 AM |
Re: Sweet Home 3D 5.7 If Info.plist is protected, you may run a command like: sudo nano /Applications/Sweet\ Home\ 3D.app/Contents/Info.plist in a Terminal window to edit it. I updated the FAQ accordingly. Have you actually tried this on a Mac running High Sierra? I have now tried everything, and there is no way I can edit the info.plist without getting a message that the program is damaged and should be thrashed. This is not a great problem for the moment, since there seems to be just minor changes in this upgrade, but it will probably be more frustrating when a major upgrade with new features is released. @Xiste Did you solve this? In that case, please tell me how. cec |
| Posted by Puybaret at Feb 19, 2018, 9:51:44 AM |
Re: Sweet Home 3D 5.7 I tried again and beside the more difficult handling of nano vs TextEdit, it worked correctly. What -Xmx text did you write between <string> and </string> ? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 30, 2026, 1:29:00 AM |
