Print at Sep 6, 2026, 4:31:23 AM View all posts in this thread on one page
Posted by otadmin at Dec 20, 2017, 11:42:48 AM
Merge two files
My plan is getting complex and my graphic card is unable to cope. To speed things up I would like to put each level in a separate .sh3d file. This way I can work on each level faster.
The problem is then combining the different files into one to have a 3d look of the whole thing.
Copy and past in another file is not working in SH. Importing plans seems also be no option.
Anybody has some advice apart from buying a more powerful computer?
Michael
Posted by Puybaret at Dec 20, 2017, 11:52:49 AM
Re: Merge two files
Copy / paste from a file to another one always works in Sweet Home 3D if you open the second file from the File > Open or File > Open recent items in the menu of the first file.
Posted by okh at Dec 20, 2017, 12:15:51 PM
Re: Merge two files
Copy and past in another file is not working in SH..
.. if you open the second file from the File > Open...
Thanks, now I understand why it works when I close down and re-open the files.
- Increase memory (in FAQ)
- Put stuff you do not need on hidden levels.
- Un-check visible.
- Enable displaying of Model size in furniture list and purge big models.
- Use simpler models for the initial process and replace later (see SF 3D models 261, scroll down for compromises).
Posted by otadmin at Dec 27, 2017, 7:48:50 AM
Re: Merge two files
Thanks! This is working indeed. Designing a passenger ship with 4 decks. Now I can furnish each deck seperatly and merge them for pictures as required. Merry Christmas.
