Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Merge two files |
| Print at Sep 6, 2026, 5:32:15 AM | |
| Posted by otadmin at Dec 20, 2017, 11:42:48 AM |
Merge two files My plan is getting complex and my graphic card is unable to cope. To speed things up I would like to put each level in a separate .sh3d file. This way I can work on each level faster. The problem is then combining the different files into one to have a 3d look of the whole thing. Copy and past in another file is not working in SH. Importing plans seems also be no option. Anybody has some advice apart from buying a more powerful computer? Michael |
| Posted by Puybaret at Dec 20, 2017, 11:52:49 AM |
Re: Merge two files Copy / paste from a file to another one always works in Sweet Home 3D if you open the second file from the File > Open or File > Open recent items in the menu of the first file. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by okh at Dec 20, 2017, 12:15:51 PM |
Re: Merge two files Copy and past in another file is not working in SH.. Thanks, now I understand why it works when I close down and re-open the files... if you open the second file from the File > Open... Anybody has some advice apart from buying a more powerful computer? - Increase memory (in FAQ)- Put stuff you do not need on hidden levels. - Un-check visible. - Enable displaying of Model size in furniture list and purge big models. - Use simpler models for the initial process and replace later (see SF 3D models 261, scroll down for compromises). |
| Posted by otadmin at Dec 27, 2017, 7:48:50 AM |
Re: Merge two files Thanks! This is working indeed. Designing a passenger ship with 4 decks. Now I can furnish each deck seperatly and merge them for pictures as required. Merry Christmas. |
Current timezone is GMT Sep 6, 2026, 5:32:15 AM |
